uriedog's avatar
uriedog
Dickinson Marine heater
Anybody using a Dickinson (or other) type propane or solid fuel heater?
I am thinking of putting one in, but would like to here some real world numbers of how they work.
  • I have a force10 Cozy Cabin Heater
    Installed in my aluminum boat. My boat is smaller than my camper, but is totally in-insulated, and even in the low 30's it will warm the cabin up to warm enough that I have to take my jacket off. Even with the stack, the propane version emits a fair amount of moisture, so if I were to consider a heater made for a boat to use in a camper, I would consider either the diesel, or better yet the solid fuel, as it is better for use boondocking to save propane for the stove.
    Garry in AK
  • I have the propane version in my 31' sailboat. Keeps it nice and warm when sailing in the high 30s to low 40s F (2-8 C). I have it mounted on a stainless steel plate that keeps the back of the heater about 5cm from the fiberglass.
    The fan is fairly quiet. Once the boat warms up we shut off the fan and run the heater on low to use less battery power for the rest of the night. Double walled chimney works well, although the cap is large, at about 15cm, with three inverted bowls on top. These keep the inlet and outlet air separated.
    The heater came with the boat. If I were to do it from scratch I'd get the diesel/kerosene burning version verses propane.
    Curious what you plan to do with it.
