HMS_Beagle
Aug 04, 2014Explorer
My view of it is that Eternabond may fail, while Dicor will fail.
Every RV I have had with Dicor on the roof has had the Dicor harden, crack, peel, and fall off. OK product I guess if you don't mind redoing it year after year.
I view Eternabond as a band aid, but with a roof seam designed to leak like the one pictured you are stuck using band aids. If you use it, make sure you roll it down very firmly. A hard narrow roller works best, you can burnish it with a spoon in a pinch.
44,056 PostsLatest Activity: Jan 01, 2026
