2012Coleman
Mar 24, 2014Explorer II
spadoctor wrote:This seems to be true in my case. Used a soft brush and spic and span on my roof. Upon rinsing, I saw specs of white stuff on the driveway. I'm no longer doing anything besides hosing off debris. My roof is made by Dicor, and the manual also states that no protectoants should be used, yet they sell rubber roof protectorent. I have also found their black streak remover to be useless. I also have downspouts, but the gutters on the awning side have been rendered useless due to the way the awning is attached - the brackets easily trap leaves and lots of caulk in the way.
I was referring to using commercial cleaners...sweeping and rinsing is basic common sense.Mine looks just like that at the end of 6 months at the seasonal site....sweep and rinse and good to go. Every time you scrub an EPDM roof you shorten the life by removing material. BTW...that is not the case with TPO roofing but still no treatments should be used.
