westend
Aug 05, 2017Explorer
keymastr wrote:It may be that they only use cheaper, conventional sealants when they are building the trailer. To endorse Eternabond tape as a better/adequate sealing solution may raise the question of why they don't use it when manufacturing.
These were guys who build them. They had no motive to suggest any product over another since they do not offer their services for hire and do not sell caulking or repair materials of any kind.
Think what you will but if the guys who build them for a living will not use a product perhaps there is a good reason.
I can only judge the adequacy of the tapes from my own use and application. Here's my story: I rebuilt an older Starcraft with an aluminum roof. I removed the roof edge trim for repair of the wooden top wall plate underneath. When I reinstalled the edge trim, I applied an elastomeric sealant between the roof membrane and the wall framing, between the wall siding and the framing, and underneath the trim edging. I used new screws to attach the edge trim and bought a new plastic screw cover. I had two small leak areas when the roof work was completed. I then applied Eternabond Web Seal and Eternabond Roof Tape over every joint and every through hole on the roof. I test about every other year, pressurizing the interior. I haven't had any leaks since using the tapes.
44,066 PostsLatest Activity: May 13, 2026
