mgirardo
Sep 06, 2020Explorer
There a couple things that will drain the battery even with everything turned off. As mentioned, the carbon monoxide detector, as well as the radio. Using the battery disconnect switch would completely cut power to those things.
It is possible you got an old battery from the dealer, but most likely no way to tell that.
If you store the trailer at the house, just keep it plugged in or put a trickle charger on the battery to keep it charged.
-Michael
-Michael
44,070 PostsLatest Activity: Jul 01, 2022
