NErunner
Sep 07, 2020Explorer
spoon059 wrote:
I'd recommend draining your water heater between trips, especially if you are going longer time periods between trips. I don't drain at the water heater, I simply open my low point drains and "burp" the water heater at the pressure bypass switch. It helps keep the pressure bypass switch from junking up with sediment/corrosion.
I open the low points and open the faucets in the bathroom to break the vacuum. All that water drains out the low point on the drive home. 8 years ago we got water from a campground that was likely from a well. Wife got really sick while pregnant and we took the summer off from camping. That water sat stagnant all summer long and stunk to high heaven when we finally got back to camping that fall. Took a couple flushes with bleach and baking powder to get that sulfur stink out of the hot water tank.
Thanks, we plan to camp every 2-3 weeks spring to fall, so maybe we should be ok not draining the water heater between trips? I guess the winterization takes care of that issue for the off season?
44,070 PostsLatest Activity: Aug 06, 2026
