Lynnmor
Sep 18, 2020Explorer II
NErunner wrote:
Hi all, just an update, I came back from camping last weekend and popped the "battery disconnect switch" that came standard in the RV, so far so good, 5 days later when turn the switch on the battery charge indicator shows 100% charge.
I'm sure you know this but I'll say it anyway. The indicator will show 100% if the trailer is plugged regardless of the state of battery charge. The charge indicators are only a crude indication of actual charge. Be sure to use the disconnect switch as soon as possible after parking so that the maximum charge is retained. It does sound like you are successful.
44,070 PostsLatest Activity: Aug 05, 2026
