crcr's avatar
crcr
Diesel Emissions Test Question
I bought a 2004.5 Ram Cummins truck one year ago, my first ever diesel vehicle. Saturday I took it to emission test it for the first time. They checked the emissions equipment, fuel cap, etc. Then for the run test, the emissions guy asked me to floor it while in Park on his signal, then release the accelerator on his follow up signal. I was kind of taken back by his request, so I didn't floor it, just tried to bring it up to the 3200 rpm redline and hold it there. That resulted in an unsteady rpm, so they told me that the readings will be all over the board if I don't floor it. I told him this engine has a 3200 rpm redline. He said the engine's governor will protect my engine.
I was required to get the truck emission tested to renew the plates, so I reluctantly did as asked. I had to do the procedure for a few seconds each of three successive times. The governor did kick in, but the engine still exceeded the redline by several hundred rpm. This experience was in Maricopa County, Arizona. My questions are:
Even though the procedure caused the engine to exceed its redline, is the governor truly protecting the engine? Are the governors reliable? I'm thinking if the governor failed during one of these tests, the result could be disastrous.
Is this typically how the diesel emissions test procedure is done in every state or metro area that has a diesel emissions test? Or is it unique?
