Turtle n Peeps wrote:
1jeep wrote:
I knew of 08 early on having radiators that leaked, I never saw it, my 08 had 140k miles. my 2011 had 110k miles never saw any issue at all.
BTW...the 6.4 he is referencing in that video was in the ford from 08-10 and was made by Navistar. 2011 to current has the 6.7 and is made by ford. 2011 up has different supports, open the hood and youll know.
if you watch to the end he mentions that the truck has bad isolators, over 200k miles and it happened when off roading. the white 450 in the beginning I can only assume has some miles on it also, but yes if I was looking at a 08-10 I would check into the isolators, and many other things as those trucks has some serious emission quirks.
Have it your way:
6.7 radiator problems
6.7 Radiator problems
You want more? There are thousands and thousands of complainers out there. This is an intrinsic problem very well known to this truck frame. It has nothing to do with a 6.4 or a 6.7 engine. It has everything to do with the frame that is under the truck that has those engines in them.
As always your right, most likely the engine already fell out of my ford and the radiator is bent in half...lol
