Traver8
May 19, 2014Explorer
My first vote goes for a leaky fuel bowl. This could be the drain valve o-rings beginning to leak some. The fuel sits on the top of the engine and just bakes off. I had the same issue but mine leaked enough so that if I parked nose high it would run off the back of the engine and drip on the ground. Did a complete fuel bowl rebuild and solved the problem. Complete rebuild kit of o-rings from DieselOrings.com was only about $20.
If you can get up and reach or look behind the fuel bowl you probably will find fuel.
Hope this helps. PM me if you need more details.
Terry
Terry
44,066 PostsLatest Activity: Mar 14, 2015
