cummins2014
May 19, 2014Explorer
Could be starting to leak out of the drain valve itself, would not see any on the motor, but if gets bad enough it will be coming out the drain pipe below the motor, and should be visible, mine was . I just replaced the entire drain valve. Cheap fix.
44,066 PostsLatest Activity: Mar 14, 2015
