tuna_fisher
Apr 09, 2020Explorer
Diesel heater
Has anybody installed a diesel heater in there TC. Would like to install where original duroFlame heater is. All the youTube videos are in Vans in random locations.
JD5150 wrote:JD, Thanks for the YT video tip, very good explanation of the heater install. Answered a lot of questions in reguards to size and space needed, which with a TC is important.tuna fisher wrote:
I've looked at YT but all are install in van, want to see in use in TC. Don't want to install tank on the outside and prefer to install in exsiting heater space where current Duro Flame is. If that can't be done I'll stick with the Duro as I don't use heater that much. My main reason for wanting is battery use, from what I understand it uses very little power.
Look up Explorer 867 on You Tube. He does a very clean install in a commercial truck canopy/cap. He has part 1 & 2 videos and the controller setup video. Total of three videos. His videos are very easy to follow.
He uses a two gallon boat fuel tank for the diesel inside the cap. Hope that helps.
