just_me
Jun 22, 2013Explorer
Charlie D. wrote:
I am seeing more and more filters made in China. Last time I tried to buy filters at NAPA, one of the Wix's and one of the NAPA's was made in China. It it matters to you, check when buying.
I believe the NAPA Gold filters are still made by Baldwin
They've always been a Wix product. Unless recently changed.
Most filters used by shops are ones that they get the best price on. Thats why you must be careful on what they use. Not bashing Fram, but the filter made for a Cummins has come apart and clogged the piston cooling nozzles causing engine failures. Also look at the construction of the filters, a lot have a bar on the bottom, that bend upon high pressure spikes and the bypass is not checked as it should be. The major manufactures use a spring for the bypass set up which is best.
Just my penny's worth.
44,056 PostsLatest Activity: Jan 01, 2026
