Charlie_D_
Oct 22, 2018Explorer
30 minutes on the highway once a week may not be necessary depending on how you drive but I agree that is the best way to clean the DPF. If there is not a message on the dash saying you are in regen you should see an increase in RPM's while idling. At that time you should try to run highway speeds as soon as possible.
I usually down shift to 4th or 5th when I need to regen. After 15-20 miles I will pull over to check if normal idle RPM's have returned. If not I will run a little further.
After you try it a few times you will be able to set a pattern of how to do it.
44,056 PostsLatest Activity: Mar 02, 2026
