Bedlam
Nov 01, 2018Moderator
NOx is produced at increased levels with elevated engine temperatures. Prior to DEF, the solution to reduce it was to run the engine colder. This resulted in more particulate matter that could plug up the DPF filter. Once DEF was introduced, engine temperatures were allowed to run hotter reducing particulates but increasing NOx. Applying the DEF as an after treatment then broke down the elevated NOx. There is an indirect interaction...
44,056 PostsLatest Activity: Mar 02, 2026
