fj12ryder
Aug 08, 2018Explorer III
If you can find where he says the original tank is "full to the brim" please point it out. Or are you assuming that's what he meant?
Uhh, I did read it, several times, which is why I asked the question. At one point he said the auxiliary tank was full, he took the cap off to see if there was a pressure build-up. Quote:
"But, it did no good. When I opened the filler tube cap, diesel continued to poor out.... In fact I would say it was gushing out." Now this was after he had taken the cap off the auxiliary tank to check for pressure build-up, so he appears to be talking about the main/OEM tank. However he says: "The original tank is 2/3 full and the auxiliary tank is full." Nowhere does he say the stock/OEM tank is full to the brim. In fact here is the first couple lines:
"Yesterday, I noticed diesel was leaking out under my truck. I checked all connections and none of them were leaking. I remove the cap from the filler tube and Diesel started pouring out.
The original tank is 2/3 full and the auxiliary tank is full. I have taken several trips with no problem."
According to that the original tank is 2/3 full and he has fuel pouring out.
44,066 PostsLatest Activity: Apr 15, 2026
