Bob Vaughn wrote:
I received an email and video from Trailer Life about Bully Dog GT tuners for diesel engines. It all sounds good but I have been warned that the warranty would be voided if I use a tuner. Now I wonder if this is true. If so then I guess I will have to wait until my warranty is up. It is 699 bucks and I wonder if there is enough of a fuel economy savings to ever break even?
#1. Yes, your warranty will be toast with a tuner.
Now, if you put a tuner on your truck and your radio or window motor goes out does that mean the dealer won't fix these things? No, not at all. What if your engine, tranny or rear end blows up? More than likely yes. All OEM's want a computer snapshot sent to them before any major work is done on their dime. IOW's if you blow your motor and want it fixed on the OEM's dime the dealer will have to send in all computer records before they can proceed to fix it.
And before anybody starts; no you can't hide a tuner from the OEM. Not going to work no matter how many times anybody says it on here.
Lets talk about fuel savings. A tuner adjusts just a few "major" things on a diesel engine. (there are more but these are the big 3)
#1. Boost pressure.
#2. Injection timing.
#3. Fuel setting.
#1. Boost pressure on a diesel engine does nothing by itself to raise power levels. IOW's if I raised my boost pressure from 30 lbs to 40 lbs I would gain nothing. On a diesel engine the turbo is on there to just keep EGT and emissions in check.
#2. When injection timing is played with you can pick up a few HP because the engine will become more efficient. This is where the tuner picks up a little mileage. Not much, but a little. Problem is NOX will go sky high if you jack up the timing rate. Same way with the gasoline engines of the 70's. Anybody remember the BB they would put in a vacuum advance lines to limit NOX? It also used a lot more fuel and killed a lot of power but it did lower NOX significantly.
#3. The big one. Fuel. Any tuner that adds more than a few HP adds fuel. No way around that no matter what people say. With a diesel engine the more fuel you add the more power you will make.
The problem is if you add more fuel your mileage will go down "if" you use that HP.
If you have a diesel engine that will use X amount of fuel at 200HP it will use 2x's X at 400HP at WOT.
Now, to answer your question. Will you get better fuel economy with a tuner? The answer is a solid maybe. It just depends on how you drive your truck while towing.
If you drive your truck with a light foot with a tuner you will see better economy than with a stock setting. Remember the injection timing and how it makes the engine more efficient? This is where the mileage savings is coming from.
If you drive your truck more aggressively you will see a drop in mileage. Remember how the tuner makes more power? Yep, with more fuel; and this is where the drop in economy will occur.
So there you have it. It just depends.
