ohioviper
Jun 06, 2007Explorer
The Iron block aluminum head works fairly well on lower compression engines , but not so well in the case of a high compression turbo Diesel.As the turbo spools up the presure increases and the higher the compression the more stress on the head gaskets to do their job. The aluminum head does not have the clamp load capability an iron head does.Tighten an aluminum head down to the same torqe spec as an iron head and you will find out why.
44,027 PostsLatest Activity: Mar 06, 2025
