azrving
Jun 09, 2017Explorer
Harleybullet wrote:
Letting you know that it was low oil level that kept from starting... had to check it manually because the light did not indicate low oil on the panel in the TC... started right up.
Once again thanks for the help and ideas......Dave
The low oil protection system is designed to shut the engine off to prevent serious damage, it's not where the oil level should be run down to as normal operation.
