Massey16
Feb 17, 2015Explorer
Difference in Gearing
Hello!
I recently sold my truck to move to a crew cab. I have come across two F-150's that are very similar save the rear end gear ratio. One has the 3.55 and the other the 3.73. The difference in towing capacity is 1000 lbs (9200 vs 8200). Either weight will be fine for the TT I have. The rear GAWR is the same between the two trucks as well. For background, I tow in a relatively flat area, around 120 miles one-way (at most), and about 6 times a year (again, at most).
So, my question is will it make a large difference for me? I know I would save gas with the 3.55's as the truck is my daily driver. The cost difference between the trucks is $1,000.
I appreciate any opinions you all care to share. Thanks!
