Terryallan
Dec 22, 2017Explorer II
TurnThePage wrote:kerrlakeRoo wrote:
Yes the weight is lower on the aluminum and azdel units if everything else remains static.
It might be slightly lower than standard aluminum framed composite RVs, but I think the sticks and tin is still lighter.
In truth. AZDL is 50 percent lighter, and has 50 percent higher R value than luan backed walls. And if you check. you will see that Stick, and tin TT are much heavier than AZDEL built TTs.
Example. My 31 foot Apex is only 4811lb dry (yellow sticker) My past 27' no slide stick, and Tin TT came in at 4975LB. Only a little over 100lb difference, but remember their is a 4 foot difference, and a 15' slide difference, and slides are very heavy.
44,071 PostsLatest Activity: Aug 30, 2026
