wnjj
Dec 22, 2017Explorer II
theoldwizard1 wrote:kerrlakeRoo wrote:
FWIW, I know I wont buy tin (aluminum) over wood on wood studs. At least for the walls. Roofs are hard to avoid, but for walls I dont want the movement that exist between layers in aluminum sided units.
I don't understand this statement.
The outer and inner fiberglass coverings are bonded (glued) to the aluminum frames and solid foam. There should be no movement.
He was referring to the wood framed with aluminum siding (stick and tin), not aluminum framed.
44,071 PostsLatest Activity: Aug 30, 2026
