Ralph_Cramden
Dec 23, 2017Explorer II
GrandpaKip wrote:
After doing a bit of math, if my camper had Azdel in the side walls, it would be roughly 100 pounds lighter and have an R-value about 0.6 higher. That higher insulation value is only in the side wall where the least amount of heat transfer takes place.
I cannot see that the selling points of “2X the insulation value and 1/2 the weight of luaun” have any real value in themselves, especially since luaun is pretty light and has an R-value of about 0.3.
The rot resistance of Azdel may have merit, except that if there is enough water intrusion to rot luaun, the Azdel will probably have come loose from the fiberglass and/or the foam.
As has been said over and over, it’s the maintenance that makes the difference.
To find which is actually lighter, you would have to find the exact same camper with both types of construction.
There is no shortage of suckers who buy into the brand website / glossy brochure glitz. .....Lightweight....literally oozing with quality.......Amish craftsmanship.....did I mention high quality?.......Azdel......Aluminum.....Revolutionary.......New and improved......Quality quality quality.......Quality control.
The best one is on every Forest River brochure they tout the dedicated QC facility as 20,000 sq ft of quality LOL........what percentage of total units produced do you think ever see the place? I know that little snippet of info told to me by a little Indiana Bird who migrated here. Less than 1%
....significantly less.
44,071 PostsLatest Activity: Aug 30, 2026
