westend
Dec 25, 2017Explorer
gmw photos wrote:
A "cheap floor" is what I consider a styro-laminate. Others are fine with it, I like plain old 3/4" tongue groove exterior plywood. Which is one of the reasons I chose this trailer. Along with flooplan.
I had a couple problem areas with my floor, (1) the area underneath the water heater where I'd assume a previous owner drained the heater and allowed the drain water to sit and (2) underneath one wall where a major leak had rotted the whole wall frame.
The rest of the subfloor (which I removed in pieces to insulate better) showed that the flooring system was intact and built as original. I have 5/8" exterior grade plywood over 2"x2" floor joists , 16" OC. The trailer is 46 yrs old.
44,071 PostsLatest Activity: Aug 30, 2026
