theoldwizard1
Dec 27, 2017Explorer II
westend wrote:
My overall observation about the aluminum roof is that, if the proper sealants would have been installed in 1971, the trailer would have remained intact and no "water infection" would have taken place.
I am not sure about that ! 47 years is a long time !! Even boat windows/port eventually need to be removed and rebedded, typically with butyl tape.
westend wrote:
I could envision a single sheet aluminum roof with CNC manipulated cutouts, a designed wall flange, and a durable attachment system to excel. The single sheet could be hoisted onto the roof frame and may be less labor than the convention of EPDM over sheet goods.
More likely, a large roll of aluminum on a spool mounted at roof level would be unwound over the underlayment that was coated with some type of adhesive. From a labor standpoint, the biggest problem would be getting it properly aligned before the adhesive "grabbed". Not sure what the best solution would be for finishing the edges or front or back.
44,071 PostsLatest Activity: Aug 30, 2026
