- path1ExplorerHave you checked out if you need friction modifier stuff?
I installed an extra capacity diff cover and used "ultra black" per instructions. - theoldwizard1Explorer IIPermatex #2 on the cover. Leave the other side dry.
- 2oldmanExplorer II
- fj12ryderExplorer III
jdc1 wrote:
Time and muscle? I must have missed that part. And yes, use the create-a-gasket stuff.agesilaus wrote:
OK this is my first time doing this. I have the correct fluid and I hope the correct gasket. My question is: do I use permatex on the gasket or leave it clean?
You've never done it before? I hope you lift weights. Pumping that oil in there takes time and muscle. Gasket? Nope. Look at the post above.....
Make sure you use the right stuff. My service manual calls for 75W-140 synthetic for my Dodge, when towing. - jdc1Explorer II
You've never done it before? I hope you lift weights. Pumping that oil in there takes time and muscle. Gasket? Nope. Look at the post above..... - Cummins12V98Explorer IIIYou should forget the gasket! This stuff is AWESOME!!! Never had a leak.
Second pic in appropriate weight if you want to do it BEST.
44,066 PostsLatest Activity: Apr 16, 2026
