webwrangler
Nov 11, 2016Explorer
I can get to the underside of the trailer. Putting some wood or metal in place to take some of the torque and pressure of the bolts sounds good. I think I'm going to poke around underneath and see if I can clear away the foam and paper to expose the subfloor from underneath. If I can do that, then I can bolt through the dinette and the subfloor without having the styrofoam as part of the equation.
I was thinking of using a hole saw to cut out a plug of styrofoam. Then I could glue it back in after the bolts are in. Have to be careful not to saw a hole in the subfloor, though...;)
Bobndot, the toothpick and glue method was my first attempt a couple of years ago, and it didn't hold up to the vibration. In this attempt, I did insert some plywood into the tubing with subfloor glue where some welds had broken, so I could put a screw through to hold the dinette together.
I will post photos if I come up with a good solution.
Thanks everybody!
Thanks everybody!
44,071 PostsLatest Activity: Aug 30, 2026
