webwrangler
Dec 07, 2016Explorer
Next step was to cut out some 1/2" OSB disks using the same hole saw I used to cut away the bottom layers. Then I inserted T-nuts into the disks, and ran bolts through the dinette frame bottom and into the T-nuts.
At the side where the dinette attaches to the wall, I had to ream out the aluminum where the two uprights met, in order to get the toggles in. I discovered that if I moved that location in order to drill only one wall upright, the table wouldn't fit on the seat edge without a moving the OTHER seat also. I'm keeping my fingers crossed that I didn't weaken the wall.
Toggles ready to go in:
All bolted down:
And sealed up underneath except for one:
The dinette seems really solid now! Hope I don't get any leaks underneath. It doesn't seem as if much water will hit the underside directly but I don't really know. Never crawled under there after towing in a rainstorm!
All bolted down:
44,071 PostsLatest Activity: Aug 30, 2026
