jayboogee
Jul 08, 2015Explorer
RedRocket204 wrote:
Per my instance, my slide switch is right next to the TT door. When I traced out the wiring (this was difficult as the wiring is in the wall) I found the wiring went to and through the floor under the TT. The +12v went to the battery however, the ground connected to my TT frame right near the fold up steps.
Good luck and let us know if you get the issue resolved.
Will definitely re-trace the wiring! The green/yellow were easy to trace from the switch, through the wall, under the fridge, to under the trailer and to motor. The 12V and Ground, I seemed to have lost somewhere, so I'll put my investigator hat on again and find that ground!
