othertonka
Jun 19, 2013Explorer
Farm Camp wrote:
Hopefully I remember this right. If not somebody will correct me:
The tabletop should pop up off of the supports. Then the support poles should pop up out of their holders that are bolte/screwed to the floor. Basically it just comes apart. Should be easy. Then the table top is laid down between the two bench seats. There should be a cleat or small board on the front of each bench set that the table top will rest on.
Then you use the bench seat back cushions to lay on the table top. And presto. You have a bed.
We just stowed the support poles under the table top once we had it lowered into position.
I Agree, This is the way I believe you do it.
