BobsYourUncle
Jun 19, 2013Nomad
Yes, that is correct.
The poles are a pressure fit so can be a bit snug. Pulling the table top off is quite easy, grab the edge and lift firmly.
When you pull the poles out, grasp them firmly and pull while rocking from side to side a little bit - couple inches each way. They will come out.
I stow mine under the unit once turned into a bed too.
