masongardner
May 20, 2015Explorer
goducks10 wrote:masongardner wrote:
Just so you know in the future, for everyone, if you see a Directv van or truck, we will give you a dish for free, usually HD, because we barely carry standard dishes anymore. Pointing an HD dish is fairy easy. Set your box to standard, align the dish to the 101 satellite, which is the standard sat, and then change your box over to HD, you should be on all 3 sat's if you have a pretty good signal on the standard.
That sounds too easy. I'm guessing you need signal strength in the 90's to be able to lock in on all 3?
Thanks for the tip.
Signal in the 90's should get your HD satellites no problem. And 90's on the standard side should be fairly easy.
