bucky wrote:
what do you do with the booties after you fuel if you can't reach the trash can from the window of your truck?
That is the tricky part.
I sat on the running board, (yes, I have one) removed booties and the gloves and put in plastic bag. Since this was the first time, I brought the bag home to photo them.
I'll hopefully be able to drive out of the dirty area and deposit bag in garbage. Or, just have a garbage bag on board.
Atlee wrote:
And don't the diesel pumps where the tractors fill up, pump at a much faster rate? It's easy to over fill a tank in a pickup.
Yes they do, like a jetstream. The nozzles are designed to be put in a very short filler tube, not a long one like I discovered years ago!
