smoothsailin's avatar
smoothsailin
Disabled Travel Trailer on a Flatbed?
Anyone have experience putting a TT on a Flatbed? We have a 23ft tandem axle TT with a bearing failure on the rear driver side. The trailer is a 2004 Forest River, standard issue. The distance from ball to rear tire is 20ft.
The trailer made it back home after a 200 mile trip when I noticed the bearing was out. The bearing nut was riding on the hub.
We have AAA emergency towing but every company they called out has failed. The first company claimed that I needed a tongue wheel. I then purchased a double wheel that replaced the tongue foot. Then the tow company claimed there is a good chance the wheel will bend when winched up the flatbed.
So what is it? Flatbed tow or not? My other option is just to tow it with my truck for the 10 miles to the repair shop.
Any ideas?
  • bgum wrote:
    Get 1 or 2 good recovery straps and tie that side of the axle to the frame. Take wheel off. Drive slow and easy and you should be able to make it to the repair facility. Stay off the brakes as much as possible.
    X2, I also have left the trailer hooked to my truck and backed it onto the tilted flatbed truck just enough to get the jack down on the flatbed. I have never tried but I don't think the tongue jack would be sturdy enough to move the trailer on.
  • Get 1 or 2 good recovery straps and tie that side of the axle to the frame. Take wheel off. Drive slow and easy and you should be able to make it to the repair facility. Stay off the brakes as much as possible.
