opnspaces wrote:
If it has valves like my trailer they look like twist valves but twisting them does nothing. You have to push them down to close them and pull them up to open them.
Here is a picture of my low point drains. Theey are also the type that you pull to open and push to close. Note that these drains are in the compartment with the hot water heater. I have also labeled the water heater bypass valves which are shown in the "normal" position. Switch all three to the oposite position for "bypass" mode.
