westend
Sep 18, 2016Explorer
Those kind of leaks usually start up higher where rain can accumulate and enter the wall. Gravity pulls the water down through the wall and onto the floor.
It looks like you have another leak with the utility knife, the scissors, and the band aid. Red stuff leaking?
I'd suggest to inspect the walls in that corner and see if everything is solid and sealed. One image you posted shows the discoloration in the corner. Since this is a utility space that is enclosed, I'd suggest to remove wall paneling in that corner and inspect. You may be able to cut the panel along the trim of the enclosure and pry the whole panel piece out of the corner. That would allow you to reinstall easily. One of the small reciprocating saws is a great tool for this kind of job.
