FLGup
Sep 18, 2016Explorer
Water test. Dry everything out first and then start with the door. Have someone pour water at the door from a hose while you look for water with a flashlight from inside. If it isn't th door, try higher up. Keep searching by trying water from different areas. Inspect caulk above....that is the usual areas.
