daystrom
Sep 19, 2016Explorer
I double what westend says. More than likely that leak is up near the roof and running down the inside of the wall. That wall board is the same stuff they use in showers so it is somewhat water impervious.
Hard to tell in the first photo but are those staples rusted near the bottom? Could just be the wallboard soaking the water up, could also indicate water coming down.
Is that the rear of the trailer and if so is there a marker light above? It looks like the darkest part of the floor is in the center. Water could be coming down the inside of the wall and the plywood is soaking it up under the floor covering. I would think if the water heater was leaking, you'd have the darker part near it.
