92DakotaHD
Sep 19, 2016Explorer
Seals look good around the lights nearby but have some marine sealant (3m 4000 UV) stuff on the way and lap sealant. Out at home and am at work when stores are open. The nails/staples right above the corner are dark but the trim just on the other side of the divider show no signs of moisture. One thing I saw up top is that the strip on either side of the roof that is screws covered by a curved strip of plastic that pops into place had popped out near the awning. I revealed around the lower awning mount bolts. Unsure if I should try the tops, just don't want to mess it up. Everything up top looks pretty sound. Going over the roof very hard when the lap sealant is here.
How much does pressure testing cost?
44,056 PostsLatest Activity: Nov 19, 2013
