dogemuffins's avatar
dogemuffins
DIY Flatbed Truck Camper Idea
I've seen very few builds online where people built their own camper on a flatbed pickup truck - most of the DIY truck campers are of the type that slide into the box - to me this seems silly, because you lose floor space and it's more material and more effort - as long as you don't care about being able to easily remove it (and I don't intend to remove it)...
I would like to purchase an older Chevy/GMC 3/4ton or 1ton flatbed pickup truck and build on that (or maybe get a regular pickup and either remove the box or build upon it), rather than the typical van chassis that most RVs use, because trucks are much easier to work on than vans.
The biggest problem I envision is height. The tall floor height means getting in and out isn't as easy as with an RV... then again, I found removable/folding stairs for cheap online that solves this problem. My other concern regarding height is that I would like to be able to stand in the van - that's why I'd prefer to go with a dually (besides, a single rear wheel flatbed is not very common)... but I'm still wondering if it'll just be too tall to be practical. I have thought about a pop up but that just seems like extra weight and engineering work that makes it anything but simple.
ANyway, I'd love to hear any reasons this is a really dumb idea (or a great idea), and/or from people that have done it. Your thoughts are appreciated!
  • Jfet wrote:
    Are you talking about building something like this?
    Yep, that's the right idea, but shorter and in one piece, not two.
  • Are you talking about building something like this?
  • Bedlam wrote:
    Instead of starting with a flatbed, why not start with a box truck?
    Definitely something I've considered - however, just like most RVs, those are usually buily on a van chassis and I want a truck chassis. I've found some u-haul trucks but they are larger than I need and mostly built on Fords - I'd prefer to stick with Chevy/GMC.
    http://sfbay.craigslist.org/eby/cto/5539076168.html
    I found that but 1. It's huge. 2. It's a Ford 3. It's pretty ugly.
    Isuzu cab over trucks are another option, but a little pricier and I don't know anything about them.
  • Instead of starting with a flatbed, why not start with a box truck?
  • GordonThree wrote:
    Sounds like a fun project. Unless lots of things are left out, I don't see how it would be cheaper to DIY than it would be to buy one that's been mass produced. Get a used one, bolt it to the flat bed and then DIY some storage boxes to fill in the areas that would otherwise be covered by the truck bed. I recognize there's some margin to be saved, but investing your own time isn't necessarily free either?
    Without the steel "hull" of the truck bed, wouldn't the camper be subject to more stress as the truck pitches and yaws on down the road? Wouldn't the underside (holding tanks?) be subject to higher risk from impact of road debris.
    I don't know much about truck campers, the biggest thing I want to learn is why they're so expensive compared to trailers trailers. There's no frame, no axle, no wheels, no suspension, no brakes, and a much smaller living space which should mean less material and less assembly time, yet they cost so much more than a trailer.
    You are spot on that if I wanted a fully featured camper with all the bells and whistles, buying a premade unit makes much more sense financially and in terms of how hard it would be to make.
    Thing is, I want something simple - no slide outs, probably not a pop up (hopefully it will be stable enough on the dually platform to be full height all the time), minimal plumbing and tanks and pumps etc.
    Assuming I start out with a flatbed truck, that will take all the abuse... so the camper doesn't get stressed/flexed/whatever.
    In terms of construction, I was thinking a simple frame of 2x4s, and wasn't sure where to go from there. Originally I was thinking of just using plywood for the outside walls, and corrugated plastic for the roof because it's very lightweight. Do you think this will be strong enough to hold itself? I think it would if I use enough wood. It might get a little heavy but that's again why I want a dually.
    I would have to decide between white or clear polycarbonate for the roof... clear would make the inside feel more spacious but might prove to be too hot and sunny when the weather is hot and the sun is shining. It would be nice to look up and see the sky, though...
    This is the material I am referring to... it comes in various colors of carying light throughput levels: http://www.homedepot.com/p/Suntuf-26-in-x-12-ft-Polycarbonate-Corrugated-Roof-Panel-in-White-101892/100041353
    That's what I'm thinking of for the roof - I'm just trying to make it as light as possible, and by using that material for the roof I won't have so much heavy stuff up there, which would help stability on highway and in the wind. On the other hand, then the roof would not be as "tough" and not as good structurally, and still would let more sun through. I'm not sure if a wood roof would be any cooler inside than the polycarbonate roof - that's where it's clear I have no expertise in the matter.
    Of course in the walls I have to incorporate things like the door (could put it in the back or on the side, undecided at this time but I'm thinking side), windows, maybe even an A/C unit... seems to me as long as I plan out beforehand and my frame is solid enough these things are not a problem.
    I'm not too worried about a heater since I can always put on a jacket or get into bed. I do plan to have a basic electrical system with a separate sealed deep cycle battery and maybe even a solar panel or something. Many things could run off 12V DC (fan, phone chargers, etc) but I do have a decent inverter I got for free that could power a laptop or something. Unfortunately the label peeled off long ago so real wattage is unknown but I'd guesstimate it's at least a 500W... enough for my needs. Again, going for simple here!
    Your idea of simply attaching a traditional cabover truck camper to the flat bed is not a bad idea, but I can't think of any way that wouldn't be ugly. Please don't take this the wrong way but in my mind that would look pretty ugly, and this truck needs to live at an apartment building so it needs to look halfway decent.
    I do 100% agree with your last point that truck campers are far overpriced. Travel trailers give you much more bang for your buck, but once again, we have nowhere to store it when we aren't using it. If that was not an issue I would go for that in a heartbeat because it's far less work, and because I already have a suitable tow vehicle for a smaller travel trailer (2002 GMC Envoy). Alas, we don't own a home so what we get has to fit in one parking spot (well, one extra parking spot, i don't think it's physically possible to fit our Honda Accord, GMC Envoy, and a dually in one assigned spot, but we can use our assigned spot and two visitor spots no problem)... lol
    I look forward to your thoughts and hearing from you if I'm nuts or if this might work.
  • Sounds like a fun project. Unless lots of things are left out, I don't see how it would be cheaper to DIY than it would be to buy one that's been mass produced. Get a used one, bolt it to the flat bed and then DIY some storage boxes to fill in the areas that would otherwise be covered by the truck bed. I recognize there's some margin to be saved, but investing your own time isn't necessarily free either?
