Houston_Remodel
Apr 18, 2016Explorer II
The 2x2 metal frame was removed from the bottom of the generator. This made it low enough to add a 3/4" thick piece of BC plywood bolted into the bottom of the generator using the factory supplied 6 threaded bolt holes.
The plywood has a cut out to accommodate the pan on the bottom of the genny.
A hole was drilled in the center to allow for a 1/2" galvanized carriage bold to be dropped through the plywood. This bolt is what attaches the plywood to the truck frame. The plywood is attached to the genny. The box is sammiched in between.
