Houston_Remodel
Apr 18, 2016Explorer II
The lid needed to be notched a little to accommodate the gas cap on the genny. I used an inside pipe cutter to remove the box lid ribs.
The bolt sticking through the box feeds into a wooden plug, the width of the hole in the bed of the truck. To keep this plug in place, a 1/2" female union nut was let into the bottom and screwed onto the carriage bolt about half way. The whole thing is tightened to the bottom of the job box, letting the plug and female union nut stick out about 1/2" as the hole in the truck sets about 1/4" below the bed of the truck. This gives me a little room to feel when the plug hits the hole and centers itself.
A 3.5 inch galvanized steel bolt is threaded through a locking washer, a piece of flat steel* with a hole in it, then another 1 1/2 inch wooden plug to center the whole unit from the bottom. The bolt assembly is threaded up through the 5th wheel hole into the female union nut, then tightened with the same impact driver and socket as the stabilizer legs.
* The steel is 2 inches wide, 8 inches long and 1/4 inch thick to act as a giant washer.
The genny is now bolted to the truck, can be used in the rain, and while traveling.
The total cost was $169, saving around $1130, and enjoyed the experience.
