Community Alumni
Apr 19, 2016Not applicable
I used those same fans in the box I built for my Champion 3650. I used a pair of 12" fans and man do they move some air. I got a lot of hours on them and they've been through some severe conditions. My box averages about 5-10 degrees over ambient. It wouldn't be a bad idea to wire in a high temp cutoff switch if the generator doesn't have one built in. Just in case the fan stops running. With mine I was able to tap the low oil sensor output and wired in a NO temperature switch. If the inside temperature gets over 130 degrees, it kills the generator.
