mobilevagrant's avatar
Jun 26, 2022
DIY Slide In Camper questions
Background - I currently have a homemade 8 foot truck camper with a slant front that I built for a dodge dakota. It's just under 80" wide. The end of the camper sits on the tailgate. I had originally make it 6.5' long to fit with the tailgate up but it was too small so I rebuilt it longer(and fixed a lot of other mistakes in the trial build). The camper is currently on my 2500 Sierra(lifted up with 2x6s and plywood since the sides are about 3" taller on this truck) and I can close the tailgate. I use mid-grade straps to mount it inside the bed at the front and using eyebolts on the camper under the wings along the inside walls and then strapped to the frame under the back of the Sierra. Took it cross country and had with no isues.
The camper is configured with a twin bed across the front under the slant, a counter on the pass side with a 3 way fridge under it at the rear and a seat on the driver's side with a 5000 BTU house A/C again at the rear. It's framed with 2x3's and sheeted outside with 1/8" plywood. I did the poor man's fiberglass on the exterior and have had no leaks. It's not pretty but it works.
First question - I've read here and on several sites that a slide in camper should not sit on anything other than the truck bed. I am kinda confused as to why this should be so. I have a 14ft ladder rack on my 8 foot bed truck that probably weighs 250lbs. I have probably put over 1000 lbs of lumber on it with no problems.
It would seem to me that having the camper sit on both the bed and the side rails would give it more stability. If it is more than an 1" higher than the sides, then the camper could wobble side to side under crosswinds, which would not be desirable at all. Plus, if using exterior tie downs, won't that pull the wings down onto the rails to an extent? I also can't imagine the weight sitting on the rails will hurt anything.
Second question - Supporting a cab-over. I'm thinking about building a larger camper now that I have the bigger Sierra. I'm debating doing a complete floor over rail since it's not really that much tall overall(I'm only 5'8" and my current camper interior is about 6' inside). That would only really add 20" in overall height and still be lower than a 5th wheel in height.
I'm just trying to figure out the best way to do the cab-over. I didn't do on with the current camper because of the drag on the dakota(it's a V6 Mag-none and pulling a flat front trailer kills it - the slant front doesnt). I don't really know if I need the whole width of the camper for the cab-over(probably going to do 8.5' wide this time).
What's the best way to support the weight of the cabover with 2 adults in the bed? I was debating running 2 2x4's stood up down both sides of the whole camper but that would only support the sides..... Could I using cables at 3 or 4 places at the bottom front of the cabover going up and then back to the back ot the camper work? The cab-over would probably only be about 4ft out with the rest inside the main part with storage under.
Thanx
  • Your biggest issue is the truck. DIY probably means heavy and that’s not where your truck shines. I think I’d go with a popup style construction. That reduce the drag and weight.
"}},"componentScriptGroups({\"componentId\":\"custom.widget.CustomFooter\"})":{"__typename":"ComponentScriptGroups","scriptGroups":{"__typename":"ComponentScriptGroupsDefinition","afterInteractive":{"__typename":"PageScriptGroupDefinition","group":"AFTER_INTERACTIVE","scriptIds":[]},"lazyOnLoad":{"__typename":"PageScriptGroupDefinition","group":"LAZY_ON_LOAD","scriptIds":[]}},"componentScripts":[]},"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/community/NavbarDropdownToggle\"]})":[{"__ref":"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/EscalatedMessageBanner\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/users/UserLink\"]})":[{"__ref":"CachedAsset:text:en_US-components/users/UserLink-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserRank\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserRank-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageTime\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageTime-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSolvedBadge\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageSubject\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageSubject-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageBody\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageBody-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageCustomFields\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageCustomFields-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageReplyButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageReplyButton-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/AcceptedSolutionButton\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/nodes/NodeView/NodeViewCard\"]})":[{"__ref":"CachedAsset:text:en_US-components/nodes/NodeView/NodeViewCard-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/messages/MessageView/MessageViewInline\"]})":[{"__ref":"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1741694506000"}],"message({\"id\":\"message:3583103\"})":{"__ref":"ForumReplyMessage:message:3583103"},"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/users/UserAvatar\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"shared/client/components/ranks/UserRankLabel\"]})":[{"__ref":"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/nodes/NodeTopicsCount\"]})":[{"__ref":"CachedAsset:text:en_US-components/nodes/NodeTopicsCount-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/nodes/NodeLatestActivityTime\"]})":[{"__ref":"CachedAsset:text:en_US-components/nodes/NodeLatestActivityTime-1741694506000"}],"cachedText({\"lastModified\":\"1741694506000\",\"locale\":\"en-US\",\"namespaces\":[\"components/tags/TagView/TagViewChip\"]})":[{"__ref":"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1741694506000"}]},"CachedAsset:pages-1742978423304":{"__typename":"CachedAsset","id":"pages-1742978423304","value":[{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"BlogViewAllPostsPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId/all-posts/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"CasePortalPage","type":"CASE_PORTAL","urlPath":"/caseportal","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"CreateGroupHubPage","type":"GROUP_HUB","urlPath":"/groups/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"CaseViewPage","type":"CASE_DETAILS","urlPath":"/case/:caseId/:caseNumber","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"InboxPage","type":"COMMUNITY","urlPath":"/inbox","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"HelpFAQPage","type":"COMMUNITY","urlPath":"/help","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"IdeaMessagePage","type":"IDEA_POST","urlPath":"/idea/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"IdeaViewAllIdeasPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/all-ideas/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"LoginPage","type":"USER","urlPath":"/signin","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"BlogPostPage","type":"BLOG","urlPath":"/category/:categoryId/blogs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ThemeEditorPage","type":"COMMUNITY","urlPath":"/designer/themes","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"TkbViewAllArticlesPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId/all-articles/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"OccasionEditPage","type":"EVENT","urlPath":"/event/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"OAuthAuthorizationAllowPage","type":"USER","urlPath":"/auth/authorize/allow","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"PageEditorPage","type":"COMMUNITY","urlPath":"/designer/pages","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"PostPage","type":"COMMUNITY","urlPath":"/category/:categoryId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ForumBoardPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"TkbBoardPage","type":"TKB","urlPath":"/category/:categoryId/kb/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"EventPostPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"UserBadgesPage","type":"COMMUNITY","urlPath":"/users/:login/:userId/badges","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"GroupHubMembershipAction","type":"GROUP_HUB","urlPath":"/membership/join/:nodeId/:membershipType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"MaintenancePage","type":"COMMUNITY","urlPath":"/maintenance","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"IdeaReplyPage","type":"IDEA_REPLY","urlPath":"/idea/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"UserSettingsPage","type":"USER","urlPath":"/mysettings/:userSettingsTab","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"GroupHubsPage","type":"GROUP_HUB","urlPath":"/groups","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ForumPostPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"OccasionRsvpActionPage","type":"OCCASION","urlPath":"/event/:boardId/:messageSubject/:messageId/rsvp/:responseType","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"VerifyUserEmailPage","type":"USER","urlPath":"/verifyemail/:userId/:verifyEmailToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"AllOccasionsPage","type":"OCCASION","urlPath":"/category/:categoryId/events/:boardId/all-events/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"EventBoardPage","type":"EVENT","urlPath":"/category/:categoryId/events/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"TkbReplyPage","type":"TKB_REPLY","urlPath":"/kb/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"IdeaBoardPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"CommunityGuideLinesPage","type":"COMMUNITY","urlPath":"/communityguidelines","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"CaseCreatePage","type":"SALESFORCE_CASE_CREATION","urlPath":"/caseportal/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"TkbEditPage","type":"TKB","urlPath":"/kb/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ForgotPasswordPage","type":"USER","urlPath":"/forgotpassword","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"IdeaEditPage","type":"IDEA","urlPath":"/idea/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"TagPage","type":"COMMUNITY","urlPath":"/tag/:tagName","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"BlogBoardPage","type":"BLOG","urlPath":"/category/:categoryId/blog/:boardId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"OccasionMessagePage","type":"OCCASION_TOPIC","urlPath":"/event/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ManageContentPage","type":"COMMUNITY","urlPath":"/managecontent","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ClosedMembershipNodeNonMembersPage","type":"GROUP_HUB","urlPath":"/closedgroup/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"CommunityPage","type":"COMMUNITY","urlPath":"/","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ForumMessagePage","type":"FORUM_TOPIC","urlPath":"/discussions/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"IdeaPostPage","type":"IDEA","urlPath":"/category/:categoryId/ideas/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"BlogMessagePage","type":"BLOG_ARTICLE","urlPath":"/blog/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"RegistrationPage","type":"USER","urlPath":"/register","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"EditGroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ForumEditPage","type":"FORUM","urlPath":"/discussions/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ResetPasswordPage","type":"USER","urlPath":"/resetpassword/:userId/:resetPasswordToken","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"TkbMessagePage","type":"TKB_ARTICLE","urlPath":"/kb/:boardId/:messageSubject/:messageId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"BlogEditPage","type":"BLOG","urlPath":"/blog/:boardId/:messageSubject/:messageId/edit","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ManageUsersPage","type":"USER","urlPath":"/users/manage/:tab?/:manageUsersTab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ForumReplyPage","type":"FORUM_REPLY","urlPath":"/discussions/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"PrivacyPolicyPage","type":"COMMUNITY","urlPath":"/privacypolicy","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"NotificationPage","type":"COMMUNITY","urlPath":"/notifications","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"UserPage","type":"USER","urlPath":"/users/:login/:userId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"HealthCheckPage","type":"COMMUNITY","urlPath":"/health","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"OccasionReplyPage","type":"OCCASION_REPLY","urlPath":"/event/:boardId/:messageSubject/:messageId/comments/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ManageMembersPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/manage/:tab?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"SearchResultsPage","type":"COMMUNITY","urlPath":"/search","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"BlogReplyPage","type":"BLOG_REPLY","urlPath":"/blog/:boardId/:messageSubject/:messageId/replies/:replyId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"GroupHubPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"TermsOfServicePage","type":"COMMUNITY","urlPath":"/termsofservice","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"CategoryPage","type":"CATEGORY","urlPath":"/category/:categoryId","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"ForumViewAllTopicsPage","type":"FORUM","urlPath":"/category/:categoryId/discussions/:boardId/all-topics/(/:after|/:before)?","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"TkbPostPage","type":"TKB","urlPath":"/category/:categoryId/kbs/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"},{"lastUpdatedTime":1742978423304,"localOverride":null,"page":{"id":"GroupHubPostPage","type":"GROUP_HUB","urlPath":"/group/:groupHubId/:boardId/create","__typename":"PageDescriptor"},"__typename":"PageResource"}],"localOverride":false},"CachedAsset:text:en_US-components/context/AppContext/AppContextProvider-0":{"__typename":"CachedAsset","id":"text:en_US-components/context/AppContext/AppContextProvider-0","value":{"noCommunity":"Cannot find community","noUser":"Cannot find current user","noNode":"Cannot find node with id {nodeId}","noMessage":"Cannot find message with id {messageId}"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-0":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-0","value":{"title":"Loading..."},"localOverride":false},"User:user:-1":{"__typename":"User","id":"user:-1","uid":-1,"login":"Community Alumni","email":"","avatar":null,"rank":null,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":"ANONYMOUS","registrationTime":null,"confirmEmailStatus":false,"registrationAccessLevel":"VIEW","ssoRegistrationFields":[]},"ssoId":null,"profileSettings":{"__typename":"ProfileSettings","dateDisplayStyle":{"__typename":"InheritableStringSettingWithPossibleValues","key":"layout.friendly_dates_enabled","value":"false","localValue":"true","possibleValues":["true","false"]},"dateDisplayFormat":{"__typename":"InheritableStringSetting","key":"layout.format_pattern_date","value":"MMM-dd-yyyy","localValue":"MM-dd-yyyy"},"language":{"__typename":"InheritableStringSettingWithPossibleValues","key":"profile.language","value":"en-US","localValue":null,"possibleValues":["en-US"]}},"deleted":false},"Theme:customTheme1":{"__typename":"Theme","id":"customTheme1"},"GroupHub:grouphub:TravelTrailer":{"__typename":"GroupHub","id":"grouphub:TravelTrailer","entityType":"GROUP_HUB","displayId":"TravelTrailer","nodeType":"grouphub","depth":2,"title":"Travel Trailer Group","shortTitle":"Travel Trailer Group","parent":{"__ref":"Category:category:TRAVELCENTER"}},"Category:category:top":{"__typename":"Category","id":"category:top","displayId":"top","nodeType":"category","depth":0,"title":"Top"},"Category:category:TRAVELCENTER":{"__typename":"Category","id":"category:TRAVELCENTER","displayId":"TRAVELCENTER","nodeType":"category","depth":1,"parent":{"__ref":"Category:category:top"},"title":"Groups","entityType":"CATEGORY","shortTitle":"Groups","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:TravelTrailerforum-board":{"__typename":"Forum","id":"board:TravelTrailerforum-board","entityType":"FORUM","displayId":"TravelTrailerforum-board","nodeType":"board","depth":3,"conversationStyle":"FORUM","title":"Travel Trailer Group","description":"","avatar":null,"profileSettings":{"__typename":"ProfileSettings","language":null},"parent":{"__ref":"GroupHub:grouphub:TravelTrailer"},"ancestors":{"__typename":"CoreNodeConnection","edges":[{"__typename":"CoreNodeEdge","node":{"__ref":"Community:community:feyqc97479"}},{"__typename":"CoreNodeEdge","node":{"__ref":"GroupHub:grouphub:TravelTrailer"}}]},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"boardPolicies":{"__typename":"BoardPolicies","canPublishArticleOnCreate":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","key":"error.lithium.policies.forums.policy_can_publish_on_create_workflow_action.accessDenied","args":[]}}},"shortTitle":"Forum","repliesProperties":{"__typename":"RepliesProperties","sortOrder":"REVERSE_PUBLISH_TIME","repliesFormat":"threaded"},"topicsCount":44028,"messageActivity":{"__typename":"MessageActivity","corePropertyChangeTime":"2025-03-27T08:52:33.633-07:00"},"eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/","tagProperties":{"__typename":"TagNodeProperties","tagsEnabled":{"__typename":"PolicyResult","failureReason":null}},"requireTags":false,"tagType":"FREEFORM_ONLY"},"Rank:rank:42":{"__typename":"Rank","id":"rank:42","position":35,"name":"Explorer","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:90171":{"__typename":"User","id":"user:90171","uid":90171,"login":"mobilevagrant","deleted":false,"avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-1.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:42"},"email":"","messagesCount":8,"biography":null,"topicsCount":2,"kudosReceivedCount":0,"kudosGivenCount":0,"kudosWeight":1,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2022-06-26T13:48:30.000-07:00","confirmEmailStatus":null},"followersCount":null,"solutionsCount":0},"ForumTopicMessage:message:3583102":{"__typename":"ForumTopicMessage","uid":3583102,"subject":"DIY Slide In Camper questions","id":"message:3583102","revisionNum":1,"repliesCount":11,"author":{"__ref":"User:user:90171"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"conversation":{"__ref":"Conversation:conversation:3583102"},"readOnly":false,"editFrozen":false,"moderationData":{"__ref":"ModerationData:moderation_data:3583102"},"body":"Background - I currently have a homemade 8 foot truck camper with a slant front that I built for a dodge dakota. It's just under 80\" wide. The end of the camper sits on the tailgate. I had originally make it 6.5' long to fit with the tailgate up but it was too small so I rebuilt it longer(and fixed a lot of other mistakes in the trial build). The camper is currently on my 2500 Sierra(lifted up with 2x6s and plywood since the sides are about 3\" taller on this truck) and I can close the tailgate. I use mid-grade straps to mount it inside the bed at the front and using eyebolts on the camper under the wings along the inside walls and then strapped to the frame under the back of the Sierra. Took it cross country and had with no isues.
The camper is configured with a twin bed across the front under the slant, a counter on the pass side with a 3 way fridge under it at the rear and a seat on the driver's side with a 5000 BTU house A/C again at the rear. It's framed with 2x3's and sheeted outside with 1/8\" plywood. I did the poor man's fiberglass on the exterior and have had no leaks. It's not pretty but it works.
It would seem to me that having the camper sit on both the bed and the side rails would give it more stability. If it is more than an 1\" higher than the sides, then the camper could wobble side to side under crosswinds, which would not be desirable at all. Plus, if using exterior tie downs, won't that pull the wings down onto the rails to an extent? I also can't imagine the weight sitting on the rails will hurt anything.
Second question - Supporting a cab-over. I'm thinking about building a larger camper now that I have the bigger Sierra. I'm debating doing a complete floor over rail since it's not really that much tall overall(I'm only 5'8\" and my current camper interior is about 6' inside). That would only really add 20\" in overall height and still be lower than a 5th wheel in height.
Thanx","body@stringLength":"3133","rawBody":"Background - I currently have a homemade 8 foot truck camper with a slant front that I built for a dodge dakota. It's just under 80\" wide. The end of the camper sits on the tailgate. I had originally make it 6.5' long to fit with the tailgate up but it was too small so I rebuilt it longer(and fixed a lot of other mistakes in the trial build). The camper is currently on my 2500 Sierra(lifted up with 2x6s and plywood since the sides are about 3\" taller on this truck) and I can close the tailgate. I use mid-grade straps to mount it inside the bed at the front and using eyebolts on the camper under the wings along the inside walls and then strapped to the frame under the back of the Sierra. Took it cross country and had with no isues.
Thanx","kudosSumWeight":0,"postTime":"2022-06-26T14:19:09.000-07:00","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"tags":{"__typename":"TagConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[{"__typename":"TagEdge","cursor":"MjUuMnwyLjF8b3wxMHxfTlZffDE","node":{"__typename":"Tag","id":"tag:Truck Campers","text":"Truck Campers","time":"2004-07-23T08:16:35.000-07:00","lastActivityTime":null,"messagesCount":null,"followersCount":null}}]},"timeToRead":3,"currentRevision":{"__ref":"Revision:revision:3583102_1"},"latestVersion":null,"metrics":{"__typename":"MessageMetrics","views":3435},"visibilityScope":"PUBLIC","canonicalUrl":null,"seoTitle":null,"seoDescription":null,"isEscalated":null,"placeholder":false,"originalMessageForPlaceholder":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"archivalData":null,"searchSnippet":"Background - I currently have a homemade 8 foot truck camper with a slant front that I built for a dodge dakota. It's just under 80\" wide. The end of the camper sits on the tailgate. I had origina...","replies":{"__typename":"MessageConnection","edges":[{"__typename":"MessageEdge","cursor":"MjUuMnwyLjF8aXwxMHwzOTowfGludCwzNTgzMTEzLDM1ODMxMDM","node":{"__ref":"ForumReplyMessage:message:3583103"}}],"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":true,"startCursor":"MjUuMnwyLjF8aXwxMHwzOTowfGludCwzNTgzMTEzLDM1ODMxMDM"}},"customFields":[]},"Conversation:conversation:3583102":{"__typename":"Conversation","id":"conversation:3583102","solved":false,"topic":{"__ref":"ForumTopicMessage:message:3583102"},"lastPostingActivityTime":"2022-06-28T16:20:03.000-07:00","lastPostTime":"2022-06-28T16:20:03.000-07:00","unreadReplyCount":11,"isSubscribed":false},"ModerationData:moderation_data:3583102":{"__typename":"ModerationData","id":"moderation_data:3583102","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"Revision:revision:3583102_1":{"__typename":"Revision","id":"revision:3583102_1","lastEditTime":"2022-06-26T14:19:09.000-07:00"},"CachedAsset:theme:customTheme1-1742978422871":{"__typename":"CachedAsset","id":"theme:customTheme1-1742978422871","value":{"id":"customTheme1","animation":{"fast":"150ms","normal":"250ms","slow":"500ms","slowest":"750ms","function":"cubic-bezier(0.07, 0.91, 0.51, 1)","__typename":"AnimationThemeSettings"},"avatar":{"borderRadius":"50%","collections":["custom"],"__typename":"AvatarThemeSettings"},"basics":{"browserIcon":{"imageAssetName":"RGB-GoodSam-Emblem-TM-Solid-SignageGreen-1709848693343.png","imageLastModified":"1709848695145","__typename":"ThemeAsset"},"customerLogo":{"imageAssetName":"4C-GoodSam-Horiz-TM_SignageGreen-1709842742388.png","imageLastModified":"1709842744704","__typename":"ThemeAsset"},"maximumWidthOfPageContent":"1250px","oneColumnNarrowWidth":"800px","gridGutterWidthMd":"30px","gridGutterWidthXs":"10px","pageWidthStyle":"WIDTH_OF_BROWSER","__typename":"BasicsThemeSettings"},"buttons":{"borderRadiusSm":"4px","borderRadius":"4px","borderRadiusLg":"4px","paddingY":"5px","paddingYLg":"7px","paddingYHero":"var(--lia-bs-btn-padding-y-lg)","paddingX":"12px","paddingXLg":"16px","paddingXHero":"60px","fontStyle":"NORMAL","fontWeight":"400","textTransform":"NONE","disabledOpacity":0.5,"primaryTextColor":"var(--lia-bs-white)","primaryTextHoverColor":"var(--lia-bs-white)","primaryTextActiveColor":"var(--lia-bs-white)","primaryBgColor":"var(--lia-bs-primary)","primaryBgHoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.85))","primaryBgActiveColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) * 0.7))","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","primaryBorderActive":"1px solid transparent","primaryBorderFocus":"1px solid var(--lia-bs-white)","primaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","secondaryTextColor":"var(--lia-bs-body-color)","secondaryTextHoverColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.95))","secondaryTextActiveColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.9))","secondaryBgColor":"var(--lia-bs-gray-300)","secondaryBgHoverColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.96))","secondaryBgActiveColor":"hsl(var(--lia-bs-gray-300-h), var(--lia-bs-gray-300-s), calc(var(--lia-bs-gray-300-l) * 0.92))","secondaryBorder":"1px solid transparent","secondaryBorderHover":"1px solid transparent","secondaryBorderActive":"1px solid transparent","secondaryBorderFocus":"1px solid transparent","secondaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","tertiaryTextColor":"var(--lia-bs-body-color)","tertiaryTextHoverColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.95))","tertiaryTextActiveColor":"hsl(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), calc(var(--lia-bs-body-color-l) * 0.9))","tertiaryBgColor":"transparent","tertiaryBgHoverColor":"transparent","tertiaryBgActiveColor":"hsla(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), var(--lia-bs-body-color-l), 0.04)","tertiaryBorder":"1px solid transparent","tertiaryBorderHover":"1px solid hsla(var(--lia-bs-body-color-h), var(--lia-bs-body-color-s), var(--lia-bs-body-color-l), 0.08)","tertiaryBorderActive":"1px solid transparent","tertiaryBorderFocus":"1px solid transparent","tertiaryBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","destructiveTextColor":"var(--lia-bs-white)","destructiveTextHoverColor":"var(--lia-bs-white)","destructiveTextActiveColor":"var(--lia-bs-white)","destructiveBgColor":"var(--lia-bs-danger)","destructiveBgHoverColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.85))","destructiveBgActiveColor":"hsl(var(--lia-bs-danger-h), var(--lia-bs-danger-s), calc(var(--lia-bs-danger-l) * 0.7))","destructiveBorder":"1px solid transparent","destructiveBorderHover":"1px solid transparent","destructiveBorderActive":"1px solid transparent","destructiveBorderFocus":"1px solid transparent","destructiveBoxShadowFocus":"0 0 0 1px var(--lia-bs-primary), 0 0 0 4px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","__typename":"ButtonsThemeSettings"},"border":{"color":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","mainContent":"LIGHT","sideContent":"NONE","radiusSm":"3px","radius":"5px","radiusLg":"9px","radius50":"100vw","__typename":"BorderThemeSettings"},"boxShadow":{"xs":"0 0 0 1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08), 0 3px 0 -1px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.08)","sm":"0 2px 4px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.06)","md":"0 5px 15px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","lg":"0 10px 30px hsla(var(--lia-bs-gray-900-h), var(--lia-bs-gray-900-s), var(--lia-bs-gray-900-l), 0.15)","__typename":"BoxShadowThemeSettings"},"cards":{"bgColor":"var(--lia-panel-bg-color)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":"var(--lia-box-shadow-xs)","__typename":"CardsThemeSettings"},"chip":{"maxWidth":"300px","height":"30px","__typename":"ChipThemeSettings"},"coreTypes":{"defaultMessageLinkColor":"var(--lia-bs-link-color)","defaultMessageLinkDecoration":"none","defaultMessageLinkFontStyle":"NORMAL","defaultMessageLinkFontWeight":"400","defaultMessageFontStyle":"NORMAL","defaultMessageFontWeight":"400","forumColor":"#23410A","forumFontFamily":"var(--lia-bs-font-family-base)","forumFontWeight":"var(--lia-default-message-font-weight)","forumLineHeight":"var(--lia-bs-line-height-base)","forumFontStyle":"var(--lia-default-message-font-style)","forumMessageLinkColor":"var(--lia-default-message-link-color)","forumMessageLinkDecoration":"var(--lia-default-message-link-decoration)","forumMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","forumMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","forumSolvedColor":"#23410A","blogColor":"#D6D6CE","blogFontFamily":"var(--lia-bs-font-family-base)","blogFontWeight":"var(--lia-default-message-font-weight)","blogLineHeight":"1.75","blogFontStyle":"var(--lia-default-message-font-style)","blogMessageLinkColor":"var(--lia-default-message-link-color)","blogMessageLinkDecoration":"var(--lia-default-message-link-decoration)","blogMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","blogMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","tkbColor":"#C7B197","tkbFontFamily":"var(--lia-bs-font-family-base)","tkbFontWeight":"var(--lia-default-message-font-weight)","tkbLineHeight":"1.75","tkbFontStyle":"var(--lia-default-message-font-style)","tkbMessageLinkColor":"var(--lia-default-message-link-color)","tkbMessageLinkDecoration":"var(--lia-default-message-link-decoration)","tkbMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","tkbMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaColor":"#4099E2","qandaFontFamily":"var(--lia-bs-font-family-base)","qandaFontWeight":"var(--lia-default-message-font-weight)","qandaLineHeight":"var(--lia-bs-line-height-base)","qandaFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkColor":"var(--lia-default-message-link-color)","qandaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","qandaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","qandaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","qandaSolvedColor":"#3FA023","ideaColor":"#FF8000","ideaFontFamily":"var(--lia-bs-font-family-base)","ideaFontWeight":"var(--lia-default-message-font-weight)","ideaLineHeight":"var(--lia-bs-line-height-base)","ideaFontStyle":"var(--lia-default-message-font-style)","ideaMessageLinkColor":"var(--lia-default-message-link-color)","ideaMessageLinkDecoration":"var(--lia-default-message-link-decoration)","ideaMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","ideaMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","contestColor":"#FCC845","contestFontFamily":"var(--lia-bs-font-family-base)","contestFontWeight":"var(--lia-default-message-font-weight)","contestLineHeight":"var(--lia-bs-line-height-base)","contestFontStyle":"var(--lia-default-message-link-font-style)","contestMessageLinkColor":"var(--lia-default-message-link-color)","contestMessageLinkDecoration":"var(--lia-default-message-link-decoration)","contestMessageLinkFontStyle":"ITALIC","contestMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","occasionColor":"#CBCBCB","occasionFontFamily":"var(--lia-bs-font-family-base)","occasionFontWeight":"var(--lia-default-message-font-weight)","occasionLineHeight":"var(--lia-bs-line-height-base)","occasionFontStyle":"var(--lia-default-message-font-style)","occasionMessageLinkColor":"var(--lia-default-message-link-color)","occasionMessageLinkDecoration":"var(--lia-default-message-link-decoration)","occasionMessageLinkFontStyle":"var(--lia-default-message-link-font-style)","occasionMessageLinkFontWeight":"var(--lia-default-message-link-font-weight)","grouphubColor":"#232323","categoryColor":"#949494","communityColor":"#FFFFFF","productColor":"#949494","__typename":"CoreTypesThemeSettings"},"colors":{"black":"#000000","white":"#FFFFFF","gray100":"#F7F7F7","gray200":"#F7F7F7","gray300":"#E8E8E8","gray400":"#D9D9D9","gray500":"#CCCCCC","gray600":"#949494","gray700":"#707070","gray800":"#545454","gray900":"#333333","dark":"#545454","light":"#F7F7F7","primary":"#23410A","secondary":"#333333","bodyText":"#232323","bodyBg":"#FFFFFF","info":"#23410A","success":"#39842B","warning":"#C3FF49","danger":"#C30B24","alertSystem":"#FF6600","textMuted":"#707070","highlight":"#FFFCAD","outline":"var(--lia-bs-primary)","custom":["#C7B197","#D6D6CE","#CBCBCB","#C3FF49","#C30B24","#F2EDEB"],"__typename":"ColorsThemeSettings"},"divider":{"size":"3px","marginLeft":"4px","marginRight":"4px","borderRadius":"50%","bgColor":"var(--lia-bs-gray-600)","bgColorActive":"var(--lia-bs-gray-600)","__typename":"DividerThemeSettings"},"dropdown":{"fontSize":"var(--lia-bs-font-size-sm)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius-sm)","dividerBg":"var(--lia-bs-gray-300)","itemPaddingY":"5px","itemPaddingX":"20px","headerColor":"var(--lia-bs-gray-700)","__typename":"DropdownThemeSettings"},"email":{"link":{"color":"#0069D4","hoverColor":"#0061c2","decoration":"none","hoverDecoration":"underline","__typename":"EmailLinkSettings"},"border":{"color":"#e4e4e4","__typename":"EmailBorderSettings"},"buttons":{"borderRadiusLg":"5px","paddingXLg":"16px","paddingYLg":"7px","fontWeight":"700","primaryTextColor":"#ffffff","primaryTextHoverColor":"#ffffff","primaryBgColor":"#0069D4","primaryBgHoverColor":"#005cb8","primaryBorder":"1px solid transparent","primaryBorderHover":"1px solid transparent","__typename":"EmailButtonsSettings"},"panel":{"borderRadius":"5px","borderColor":"#e4e4e4","__typename":"EmailPanelSettings"},"__typename":"EmailThemeSettings"},"emoji":{"skinToneDefault":"#ffcd43","skinToneLight":"#fae3c5","skinToneMediumLight":"#e2cfa5","skinToneMedium":"#daa478","skinToneMediumDark":"#a78058","skinToneDark":"#5e4d43","__typename":"EmojiThemeSettings"},"heading":{"color":"var(--lia-bs-body-color)","fontFamily":"Aeonik Pro","fontStyle":"NORMAL","fontWeight":"700","h1FontSize":"56px","h2FontSize":"45px","h3FontSize":"38px","h4FontSize":"32px","h5FontSize":"26px","h6FontSize":"24px","lineHeight":"1.3","subHeaderFontSize":"18px","subHeaderFontWeight":"500","h1LetterSpacing":"normal","h2LetterSpacing":"normal","h3LetterSpacing":"normal","h4LetterSpacing":"normal","h5LetterSpacing":"normal","h6LetterSpacing":"normal","subHeaderLetterSpacing":"2px","h1FontWeight":"var(--lia-bs-headings-font-weight)","h2FontWeight":"var(--lia-bs-headings-font-weight)","h3FontWeight":"var(--lia-bs-headings-font-weight)","h4FontWeight":"var(--lia-bs-headings-font-weight)","h5FontWeight":"var(--lia-bs-headings-font-weight)","h6FontWeight":"var(--lia-bs-headings-font-weight)","__typename":"HeadingThemeSettings"},"icons":{"size10":"10px","size12":"12px","size14":"14px","size16":"16px","size20":"20px","size24":"24px","size30":"30px","size40":"40px","size50":"50px","size60":"60px","size80":"80px","size120":"120px","size160":"160px","__typename":"IconsThemeSettings"},"imagePreview":{"bgColor":"var(--lia-bs-gray-900)","titleColor":"var(--lia-bs-white)","controlColor":"var(--lia-bs-white)","controlBgColor":"var(--lia-bs-gray-800)","__typename":"ImagePreviewThemeSettings"},"input":{"borderColor":"var(--lia-bs-gray-600)","disabledColor":"var(--lia-bs-gray-600)","focusBorderColor":"var(--lia-bs-primary)","labelMarginBottom":"10px","btnFontSize":"var(--lia-bs-font-size-sm)","focusBoxShadow":"0 0 0 3px hsla(var(--lia-bs-primary-h), var(--lia-bs-primary-s), var(--lia-bs-primary-l), 0.2)","checkLabelMarginBottom":"2px","checkboxBorderRadius":"3px","borderRadiusSm":"var(--lia-bs-border-radius-sm)","borderRadius":"var(--lia-bs-border-radius)","borderRadiusLg":"var(--lia-bs-border-radius-lg)","formTextMarginTop":"4px","textAreaBorderRadius":"var(--lia-bs-border-radius)","activeFillColor":"var(--lia-bs-primary)","__typename":"InputThemeSettings"},"loading":{"dotDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.2)","dotLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.5)","barDarkColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.06)","barLightColor":"hsla(var(--lia-bs-white-h), var(--lia-bs-white-s), var(--lia-bs-white-l), 0.4)","__typename":"LoadingThemeSettings"},"link":{"color":"var(--lia-bs-primary)","hoverColor":"hsl(var(--lia-bs-primary-h), var(--lia-bs-primary-s), calc(var(--lia-bs-primary-l) - 10%))","decoration":"none","hoverDecoration":"underline","__typename":"LinkThemeSettings"},"listGroup":{"itemPaddingY":"15px","itemPaddingX":"15px","borderColor":"var(--lia-bs-gray-300)","__typename":"ListGroupThemeSettings"},"modal":{"contentTextColor":"var(--lia-bs-body-color)","contentBg":"var(--lia-bs-white)","backgroundBg":"var(--lia-bs-white)","smSize":"440px","mdSize":"760px","lgSize":"1080px","backdropOpacity":0.3,"contentBoxShadowXs":"var(--lia-bs-box-shadow-sm)","contentBoxShadow":"var(--lia-bs-box-shadow)","headerFontWeight":"700","__typename":"ModalThemeSettings"},"navbar":{"position":"FIXED","background":{"attachment":null,"clip":null,"color":"var(--lia-bs-white)","imageAssetName":"","imageLastModified":"0","origin":null,"position":"CENTER_CENTER","repeat":"NO_REPEAT","size":"COVER","__typename":"BackgroundProps"},"backgroundOpacity":0.8,"paddingTop":"15px","paddingBottom":"15px","borderBottom":"1px solid var(--lia-bs-border-color)","boxShadow":"var(--lia-bs-box-shadow-sm)","brandMarginRight":"30px","brandMarginRightSm":"10px","brandLogoHeight":"30px","linkGap":"10px","linkJustifyContent":"flex-start","linkPaddingY":"5px","linkPaddingX":"10px","linkDropdownPaddingY":"9px","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkColor":"var(--lia-bs-body-color)","linkHoverColor":"var(--lia-bs-primary)","linkFontSize":"var(--lia-bs-font-size-sm)","linkFontStyle":"NORMAL","linkFontWeight":"400","linkTextTransform":"NONE","linkLetterSpacing":"normal","linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkBgColor":"transparent","linkBgHoverColor":"transparent","linkBorder":"none","linkBorderHover":"none","linkBoxShadow":"none","linkBoxShadowHover":"none","linkTextBorderBottom":"none","linkTextBorderBottomHover":"none","dropdownPaddingTop":"10px","dropdownPaddingBottom":"15px","dropdownPaddingX":"10px","dropdownMenuOffset":"2px","dropdownDividerMarginTop":"10px","dropdownDividerMarginBottom":"10px","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","controllerIconColor":"var(--lia-bs-body-color)","controllerIconHoverColor":"var(--lia-bs-body-color)","controllerTextColor":"var(--lia-nav-controller-icon-color)","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","controllerHighlightColor":"hsla(30, 100%, 50%)","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerColor":"var(--lia-nav-controller-icon-color)","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","hamburgerBgColor":"transparent","hamburgerBgHoverColor":"transparent","hamburgerBorder":"none","hamburgerBorderHover":"none","collapseMenuMarginLeft":"20px","collapseMenuDividerBg":"var(--lia-nav-link-color)","collapseMenuDividerOpacity":0.16,"__typename":"NavbarThemeSettings"},"pager":{"textColor":"var(--lia-bs-link-color)","textFontWeight":"var(--lia-font-weight-md)","textFontSize":"var(--lia-bs-font-size-sm)","__typename":"PagerThemeSettings"},"panel":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-bs-border-radius)","borderColor":"var(--lia-bs-border-color)","boxShadow":"none","__typename":"PanelThemeSettings"},"popover":{"arrowHeight":"8px","arrowWidth":"16px","maxWidth":"300px","minWidth":"100px","headerBg":"var(--lia-bs-white)","borderColor":"var(--lia-bs-border-color)","borderRadius":"var(--lia-bs-border-radius)","boxShadow":"0 0.5rem 1rem hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.15)","__typename":"PopoverThemeSettings"},"prism":{"color":"#000000","bgColor":"#f5f2f0","fontFamily":"var(--font-family-monospace)","fontSize":"var(--lia-bs-font-size-base)","fontWeightBold":"var(--lia-bs-font-weight-bold)","fontStyleItalic":"italic","tabSize":2,"highlightColor":"#b3d4fc","commentColor":"#62707e","punctuationColor":"#6f6f6f","namespaceOpacity":"0.7","propColor":"#990055","selectorColor":"#517a00","operatorColor":"#906736","operatorBgColor":"hsla(0, 0%, 100%, 0.5)","keywordColor":"#0076a9","functionColor":"#d3284b","variableColor":"#c14700","__typename":"PrismThemeSettings"},"rte":{"bgColor":"var(--lia-bs-white)","borderRadius":"var(--lia-panel-border-radius)","boxShadow":" var(--lia-panel-box-shadow)","customColor1":"#bfedd2","customColor2":"#fbeeb8","customColor3":"#f8cac6","customColor4":"#eccafa","customColor5":"#c2e0f4","customColor6":"#2dc26b","customColor7":"#f1c40f","customColor8":"#e03e2d","customColor9":"#b96ad9","customColor10":"#3598db","customColor11":"#169179","customColor12":"#e67e23","customColor13":"#ba372a","customColor14":"#843fa1","customColor15":"#236fa1","customColor16":"#ecf0f1","customColor17":"#ced4d9","customColor18":"#95a5a6","customColor19":"#7e8c8d","customColor20":"#34495e","customColor21":"#000000","customColor22":"#ffffff","defaultMessageHeaderMarginTop":"40px","defaultMessageHeaderMarginBottom":"20px","defaultMessageItemMarginTop":"0","defaultMessageItemMarginBottom":"30px","diffAddedColor":"hsla(170, 53%, 51%, 0.4)","diffChangedColor":"hsla(43, 97%, 63%, 0.4)","diffNoneColor":"hsla(0, 0%, 80%, 0.4)","diffRemovedColor":"hsla(9, 74%, 47%, 0.4)","specialMessageHeaderMarginTop":"40px","specialMessageHeaderMarginBottom":"20px","specialMessageItemMarginTop":"0","specialMessageItemMarginBottom":"30px","__typename":"RteThemeSettings"},"tags":{"bgColor":"var(--lia-bs-gray-200)","bgHoverColor":"var(--lia-bs-gray-400)","borderRadius":"var(--lia-bs-border-radius-sm)","color":"var(--lia-bs-body-color)","hoverColor":"var(--lia-bs-body-color)","fontWeight":"var(--lia-font-weight-md)","fontSize":"var(--lia-font-size-xxs)","textTransform":"UPPERCASE","letterSpacing":"0.5px","__typename":"TagsThemeSettings"},"toasts":{"borderRadius":"var(--lia-bs-border-radius)","paddingX":"12px","__typename":"ToastsThemeSettings"},"typography":{"fontFamilyBase":"Aeonik","fontStyleBase":"NORMAL","fontWeightBase":"400","fontWeightLight":"300","fontWeightNormal":"400","fontWeightMd":"500","fontWeightBold":"700","letterSpacingSm":"normal","letterSpacingXs":"normal","lineHeightBase":"1.5","fontSizeBase":"18px","fontSizeXxs":"11px","fontSizeXs":"14px","fontSizeSm":"16px","fontSizeLg":"20px","fontSizeXl":"24px","smallFontSize":"14px","customFonts":[{"source":"SERVER","name":"Aeonik","styles":[{"style":"NORMAL","weight":"400","__typename":"FontStyleData"},{"style":"ITALIC","weight":"400","__typename":"FontStyleData"},{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"ITALIC","weight":"700","__typename":"FontStyleData"}],"assetNames":["Aeonik-normal-400.woff2","Aeonik-italic-400.woff2","Aeonik-normal-700.woff2","Aeonik-italic-700.woff2"],"__typename":"CustomFont"},{"source":"SERVER","name":"Aeonik Pro","styles":[{"style":"NORMAL","weight":"700","__typename":"FontStyleData"},{"style":"NORMAL","weight":"400","__typename":"FontStyleData"}],"assetNames":["AeonikPro-normal-700.woff2","AeonikPro-normal-400.woff2"],"__typename":"CustomFont"}],"__typename":"TypographyThemeSettings"},"unstyledListItem":{"marginBottomSm":"5px","marginBottomMd":"10px","marginBottomLg":"15px","marginBottomXl":"20px","marginBottomXxl":"25px","__typename":"UnstyledListItemThemeSettings"},"yiq":{"light":"#ffffff","dark":"#000000","__typename":"YiqThemeSettings"},"colorLightness":{"primaryDark":0.36,"primaryLight":0.74,"primaryLighter":0.89,"primaryLightest":0.95,"infoDark":0.39,"infoLight":0.72,"infoLighter":0.85,"infoLightest":0.93,"successDark":0.24,"successLight":0.62,"successLighter":0.8,"successLightest":0.91,"warningDark":0.39,"warningLight":0.68,"warningLighter":0.84,"warningLightest":0.93,"dangerDark":0.41,"dangerLight":0.72,"dangerLighter":0.89,"dangerLightest":0.95,"__typename":"ColorLightnessThemeSettings"},"localOverride":false,"__typename":"Theme"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/Loading/LoadingDot-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/Loading/LoadingDot-1741694506000","value":{"title":"Loading..."},"localOverride":false},"CachedAsset:quilt:campingworld.prod:pages/forums/ForumMessagePage:board:TravelTrailerforum-board-1743092575224":{"__typename":"CachedAsset","id":"quilt:campingworld.prod:pages/forums/ForumMessagePage:board:TravelTrailerforum-board-1743092575224","value":{"id":"ForumMessagePage","container":{"id":"Common","headerProps":{"backgroundImageProps":null,"backgroundColor":null,"addComponents":null,"removeComponents":["community.widget.bannerWidget"],"componentOrder":null,"__typename":"QuiltContainerSectionProps"},"headerComponentProps":{"community.widget.breadcrumbWidget":{"disableLastCrumbForDesktop":false}},"footerProps":null,"footerComponentProps":null,"items":[{"id":"message-list","layout":"MAIN_SIDE","bgColor":null,"showTitle":null,"showDescription":null,"textPosition":null,"textColor":null,"sectionEditLevel":null,"bgImage":null,"disableSpacing":null,"edgeToEdgeDisplay":null,"fullHeight":null,"showBorder":null,"__typename":"MainSideQuiltSection","columnMap":{"main":[{"id":"messages.widget.topicWithThreadedReplyListWidget","className":"lia-topic-with-replies","props":{"editLevel":"CONFIGURE"},"__typename":"QuiltComponent"}],"side":[{"id":"nodes.widget.nodeActionButtonWidget","className":null,"props":{"buttonAlignment":"right","instanceId":null,"buttonStyle":"md","actionButtonTitle":"Start a New Discussion","lazyLoad":false,"buttonWidth":"full_width"},"__typename":"QuiltComponent"},{"id":"nodes.widget.nodeInformationWidget","className":null,"props":{"instanceId":null,"useWidgetTitle":true,"viewVariant":{"type":"card","props":{"useNodePostCount":true,"useNodeFollowersCount":false,"useNodeDescription":true,"useNodeTopicsCount":false,"useNodeAction":true,"useNodeMembersCount":false,"useNodeMembershipType":false,"useNodeTitle":false,"useNodeMembersCountText":false,"useNodeMembership":false,"useNodeCreationDate":false,"textAlignment":"center","useWidgetTitle":true,"useNodeOwners":false,"useNodeAvatar":false,"useNodeLatestActivityTime":true,"descriptionClampLines":2,"useClickableCard":false}},"alignment":"center","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"messages.widget.relatedContentWidget","className":null,"props":{"hideIfEmpty":true,"enablePagination":false,"useTitle":true,"listVariant":{"type":"unstyled","props":{"listItemSpacing":"xxl"}},"pageSize":5,"style":"compact","pagerVariant":{"type":"none"},"viewVariant":{"type":"inline","props":{"useRepliesCount":false,"useMedia":false,"useAuthorRank":false,"useNode":false,"boardIconSize":"24","useAuthorLoginLink":true,"useNodeLink":true,"usePreviewMedia":true,"timeStampType":"postTime","useTextBody":true,"useSolvedBadge":false,"subjectAs":"h6","renderPostTimeBeforeAuthor":true,"useAvatar":true,"useVideoPreview":false,"portraitClampBodyLines":3,"useCompactSpacing":true,"useTimeToRead":false,"useSpoilerFreeBody":true,"useKudosCount":false,"useViewCount":false,"useBody":false,"useTags":false,"clampSubjectLines":1,"useBoardIcon":false,"useMessageTimeLink":true,"useAuthorLogin":true}},"lazyLoad":false,"panelType":"standard"},"__typename":"QuiltComponent"}],"__typename":"MainSideSectionColumns"}}],"__typename":"QuiltContainer"},"__typename":"Quilt","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/EmailVerification-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/common/EmailVerification-1741694506000","value":{"email.verification.title":"Email Verification Required","email.verification.message.update.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. To change your email, visit My Settings.","email.verification.message.resend.email":"To participate in the community, you must first verify your email address. The verification email was sent to {email}. Resend email."},"localOverride":false},"CachedAsset:text:en_US-pages/forums/ForumMessagePage-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-pages/forums/ForumMessagePage-1741694506000","value":{"title":"{contextMessageSubject} | {communityTitle}","errorMissing":"This message cannot be found","name":"Forum Message Page","section.message-list.title":"Forum Discussion","archivedMessageTitle":"This Content Has Been Archived"},"localOverride":false},"CachedAsset:quiltWrapper:campingworld.prod:Common:1742978336686":{"__typename":"CachedAsset","id":"quiltWrapper:campingworld.prod:Common:1742978336686","value":{"id":"Common","header":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"community.widget.navbarWidget","props":{"showUserName":true,"showRegisterLink":true,"useIconLanguagePicker":true,"useLabelLanguagePicker":true,"links":{"sideLinks":[{"children":[],"linkType":"EXTERNAL","id":"migrated-link-7","url":"https://www.goodsam.com","target":"BLANK"},{"children":[],"linkType":"EXTERNAL","id":"migrated-link-8","url":"https://myaccount.goodsam.com/myrewards","target":"BLANK"}],"mainLinks":[{"children":[],"linkType":"INTERNAL","id":"migrated-link-0","params":{"categoryId":"RVTalk"},"routeName":"CategoryPage"},{"children":[],"linkType":"INTERNAL","id":"migrated-link-1","params":{"categoryId":"TRAVELCENTER"},"routeName":"CategoryPage"},{"children":[],"linkType":"EXTERNAL","id":"Common-external-link","url":"https://community.goodsam.com/category/top/events/events","target":"SELF"},{"children":[{"linkType":"INTERNAL","id":"Common-announcements_blog-link","params":{"boardId":"Announcements_Blog","categoryId":"top"},"routeName":"BlogBoardPage"},{"linkType":"INTERNAL","id":"Common-get-support-ask-questions-link","params":{"boardId":"GetSupportAskQuestions","categoryId":"top"},"routeName":"ForumBoardPage"},{"linkType":"INTERNAL","id":"Common-community-feedback-link","params":{"boardId":"CommunityFeedback","categoryId":"top"},"routeName":"ForumBoardPage"}],"linkType":"INTERNAL","id":"migrated-link-3","params":{"boardId":"Announcements_Blog","categoryId":"top"},"routeName":"BlogBoardPage"},{"children":[],"linkType":"INTERNAL","id":"Common-admin-mods-private-link","params":{"categoryId":"AdminModsPrivate"},"routeName":"CategoryPage"}]},"className":"QuiltComponent_lia-component-edit-mode__0nCcm","style":{"boxShadow":"var(--lia-bs-box-shadow-sm)","linkFontWeight":"400","controllerHighlightColor":"var(--lia-bs-body-color)","dropdownDividerMarginBottom":"10px","hamburgerBorderHover":"none","linkFontSize":"16px","linkBoxShadowHover":"none","backgroundOpacity":0.8,"controllerBorderRadius":"var(--lia-border-radius-50)","hamburgerBgColor":"transparent","linkTextBorderBottom":"none","hamburgerColor":"var(--lia-nav-controller-icon-color)","brandLogoHeight":"30px","linkLetterSpacing":"normal","linkBgHoverColor":"transparent","collapseMenuDividerOpacity":0.16,"paddingBottom":"15px","dropdownPaddingBottom":"15px","dropdownMenuOffset":"2px","hamburgerBgHoverColor":"transparent","borderBottom":"1px solid var(--lia-bs-border-color)","hamburgerBorder":"none","dropdownPaddingX":"10px","brandMarginRightSm":"10px","linkBoxShadow":"none","linkJustifyContent":"flex-start","linkColor":"notFound","collapseMenuDividerBg":"var(--lia-nav-link-color)","dropdownPaddingTop":"10px","controllerHighlightTextColor":"var(--lia-yiq-light)","controllerTextColor":"var(--lia-nav-controller-icon-color)","background":{"imageAssetName":"","color":"var(--lia-bs-white)","size":"COVER","repeat":"NO_REPEAT","position":"CENTER_CENTER","imageLastModified":""},"linkBorderRadius":"var(--lia-bs-border-radius-sm)","linkHoverColor":"notFound","position":"FIXED","linkBorder":"none","linkTextBorderBottomHover":"2px solid var(--lia-bs-primary)","brandMarginRight":"30px","hamburgerHoverColor":"var(--lia-nav-controller-icon-color)","linkBorderHover":"none","collapseMenuMarginLeft":"20px","linkFontStyle":"NORMAL","linkPaddingX":"10px","controllerTextHoverColor":"var(--lia-nav-controller-icon-hover-color)","paddingTop":"15px","linkPaddingY":"5px","linkTextTransform":"NONE","dropdownBorderColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.08)","controllerBgHoverColor":"hsla(var(--lia-bs-black-h), var(--lia-bs-black-s), var(--lia-bs-black-l), 0.1)","linkDropdownPaddingX":"var(--lia-nav-link-px)","linkBgColor":"transparent","linkDropdownPaddingY":"9px","controllerIconColor":"var(--lia-bs-body-color)","dropdownDividerMarginTop":"10px","linkGap":"10px","controllerIconHoverColor":"var(--lia-bs-body-color)"},"showSearchIcon":true,"languagePickerStyle":"iconAndLabel"},"__typename":"QuiltComponent"},{"id":"community.widget.breadcrumbWidget","props":{"backgroundColor":"transparent","linkHighlightColor":"var(--lia-bs-gray-600)","visualEffects":{"showBottomBorder":true},"linkTextColor":"var(--lia-bs-black)"},"__typename":"QuiltComponent"},{"id":"community.widget.bannerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"footer":{"backgroundImageProps":{"assetName":null,"backgroundSize":"COVER","backgroundRepeat":"NO_REPEAT","backgroundPosition":"CENTER_CENTER","lastModified":null,"__typename":"BackgroundImageProps"},"backgroundColor":"transparent","items":[{"id":"custom.widget.CustomFooter","props":{"widgetVisibility":"signedInOrAnonymous","useTitle":true,"useBackground":false,"title":"","lazyLoad":false},"__typename":"QuiltComponent"},{"id":"community.widget.footerWidget","props":null,"__typename":"QuiltComponent"}],"__typename":"QuiltWrapperSection"},"__typename":"QuiltWrapper","localOverride":false},"localOverride":false},"CachedAsset:text:en_US-components/common/ActionFeedback-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/common/ActionFeedback-1741694506000","value":{"joinedGroupHub.title":"Welcome","joinedGroupHub.message":"You are now a member of this group and are subscribed to updates.","groupHubInviteNotFound.title":"Invitation Not Found","groupHubInviteNotFound.message":"Sorry, we could not find your invitation to the group. The owner may have canceled the invite.","groupHubNotFound.title":"Group Not Found","groupHubNotFound.message":"The grouphub you tried to join does not exist. It may have been deleted.","existingGroupHubMember.title":"Already Joined","existingGroupHubMember.message":"You are already a member of this group.","accountLocked.title":"Account Locked","accountLocked.message":"Your account has been locked due to multiple failed attempts. Try again in {lockoutTime} minutes.","editedGroupHub.title":"Changes Saved","editedGroupHub.message":"Your group has been updated.","leftGroupHub.title":"Goodbye","leftGroupHub.message":"You are no longer a member of this group and will not receive future updates.","deletedGroupHub.title":"Deleted","deletedGroupHub.message":"The group has been deleted.","groupHubCreated.title":"Group Created","groupHubCreated.message":"{groupHubName} is ready to use","accountClosed.title":"Account Closed","accountClosed.message":"The account has been closed and you will now be redirected to the homepage","resetTokenExpired.title":"Reset Password Link has Expired","resetTokenExpired.message":"Try resetting your password again","invalidUrl.title":"Invalid URL","invalidUrl.message":"The URL you're using is not recognized. Verify your URL and try again.","accountClosedForUser.title":"Account Closed","accountClosedForUser.message":"{userName}'s account is closed","inviteTokenInvalid.title":"Invitation Invalid","inviteTokenInvalid.message":"Your invitation to the community has been canceled or expired.","inviteTokenError.title":"Invitation Verification Failed","inviteTokenError.message":"The url you are utilizing is not recognized. Verify your URL and try again","pageNotFound.title":"Access Denied","pageNotFound.message":"You do not have access to this area of the community or it doesn't exist","eventAttending.title":"Responded as Attending","eventAttending.message":"You'll be notified when there's new activity and reminded as the event approaches","eventInterested.title":"Responded as Interested","eventInterested.message":"You'll be notified when there's new activity and reminded as the event approaches","eventNotFound.title":"Event Not Found","eventNotFound.message":"The event you tried to respond to does not exist.","redirectToRelatedPage.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.title":"Showing Related Content","redirectToRelatedPageForBaseUsers.message":"The content you are trying to access is archived","redirectToRelatedPage.message":"The content you are trying to access is archived","relatedUrl.archivalLink.flyoutMessage":"The content you are trying to access is archived View Archived Content"},"localOverride":false},"CachedAsset:component:custom.widget.CustomFooter-en-1742978438033":{"__typename":"CachedAsset","id":"component:custom.widget.CustomFooter-en-1742978438033","value":{"component":{"id":"custom.widget.CustomFooter","template":{"id":"CustomFooter","markupLanguage":"HANDLEBARS","style":"$bootstrap-padding: 15px;\n$goodsam-gray: #474442;\n$goodsam-gray-200: #eaecef;\n$goodsam-gray-400: #c7c7c7;\n$goodsam-gray-700: #666;\n$goodsam-gray-footer: #dfdfdf;\n\n$theme-type-size-xsmall: 12px;\n$theme-type-size-small: 14px;\n$theme-type-size-base: 16px;\n$theme-type-size-large: 18px;\n$theme-type-size-xlarge: 20px;\n\n$font-weight-content: 100;\n\n$theme-space-xsmall: 5px;\n$theme-space-small: 10px;\n$theme-space-base: 20px;\n$theme-space-large: 40px;\n$theme-space-xlarge: 60px;\n.footer-wrapper {\n background: $goodsam-gray;\n\n a {\n color: $goodsam-gray-footer;\n font-weight: $font-weight-content;\n\n &:focus,\n &:hover {\n color: $goodsam-gray-footer;\n }\n }\n}\n.sr-only {\n position: absolute;\n width: 1px;\n height: 1px;\n margin: -1px;\n padding: 0;\n overflow: hidden;\n clip: rect(0, 0, 0, 0);\n border: 0;\n}\n.footer {\n line-height: $theme-type-size-xlarge;\n /* margin-left: auto;\n\tmargin-right: auto;\n\tpadding-left: $bootstrap-padding;\n\tpadding-right: $bootstrap-padding; */\n}\n\n.container {\n margin-left: auto;\n margin-right: auto;\n max-width: 1170px;\n padding-left: $bootstrap-padding;\n padding-right: $bootstrap-padding;\n}\n\n.row {\n /* HOTFIX - PSDS-32115 - Remove negative margins to fix mobile display */\n\n &::after {\n clear: both;\n }\n\n &::after,\n &::before {\n content: ' ';\n display: table;\n }\n}\n\n.col {\n float: left;\n min-height: 1px;\n padding-left: $bootstrap-padding;\n padding-right: $bootstrap-padding;\n position: relative;\n}\n\n.col-xs-10,\n.col-sm-10 {\n width: 83.33333333%;\n}\n\n.col-xs-12,\n.col-sm-4,\n.col-sm-12,\n.col-md-2,\n.col-md-8,\n.col-md-10,\n.col-md-12,\n.col-lg-2,\n.col-lg-8,\n.col-lg-12 {\n width: 100%;\n}\n\n@media screen and (min-width: 767px) {\n .col-md-2 {\n width: 16.66666667%;\n }\n\n .col-md-8 {\n width: 66.66666667%;\n }\n\n .col-md-10 {\n width: 83.33333333%;\n }\n\n .col-md-12 {\n width: 100%;\n }\n}\n\n@media screen and (min-width: 992px) {\n .col-lg-2 {\n width: 16.66666667%;\n }\n\n .col-lg-4 {\n /* faking it; should be 33.33333333% */\n width: 25%;\n }\n\n .col-lg-8 {\n /* faking it; should be 66.66666667% */\n width: 75%;\n }\n\n .col-lg-10 {\n width: 83.33333333%;\n }\n\n .col-lg-12 {\n width: 100%;\n }\n}\n\n.pull-left {\n float: left;\n width: 100%;\n\n @media screen and (min-width: 767px) {\n float: none;\n width: auto;\n }\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n}\n\n.pad-bottom-20 {\n padding-bottom: $theme-space-base;\n}\n\n.pad-top-20 {\n padding-top: $theme-space-base;\n}\n\n.pad-top-30 {\n padding-top: calc($bootstrap-padding * 2);\n}\n\n.pad-top-40 {\n @media screen and (min-width: 992px) {\n padding-top: $theme-space-large;\n }\n}\n\n.margin-left-20 {\n @media screen and (min-width: 992px) {\n margin-left: $theme-space-base;\n }\n}\n\n.margin-top-20 {\n @media screen and (min-width: 992px) {\n margin-top: $theme-space-base;\n }\n}\n\n.text-center {\n text-align: center;\n}\n\n.text-right {\n text-align: right;\n}\n\n.text-smaller,\n.text-small {\n font-size: $theme-type-size-xsmall;\n}\n\n.text-large {\n font-size: $theme-type-size-xlarge;\n}\n\n.footer-contact {\n p {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n .text-small {\n @media screen and (max-width: 991px) {\n font-size: $theme-type-size-base;\n }\n }\n }\n\n .icon-gs-app {\n margin-right: $theme-space-base;\n max-width: 38px;\n padding-right: 2px;\n padding-top: 2px;\n\n @media screen and (min-width: 992px) {\n margin-left: 140px;\n margin-right: 0;\n }\n }\n\n .gsi-icon-phone {\n margin-bottom: -2px;\n margin-right: $theme-space-small;\n max-height: 20px;\n width: 20px;\n\n @media screen and (min-width: 992px) {\n margin-right: 0;\n }\n }\n}\n\n.footer-link {\n a,\n button {\n color: $goodsam-gray-footer;\n padding: 0 12px 0 $theme-space-small;\n }\n\n li:last-child a {\n padding-right: 0;\n }\n}\n\n.footer-top-links {\n padding-left: 0;\n list-style: none;\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n margin-bottom: $theme-space-small;\n font-size: 16px;\n\n @media screen and (max-width: 480px) {\n flex-direction: column;\n }\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n margin-bottom: $theme-space-base;\n padding: 0 $theme-space-base;\n\n @media screen and (min-width: 992px) {\n padding: 0;\n }\n }\n}\n\n.footer-top {\n border-bottom: 2px solid $goodsam-gray-400;\n display: block;\n margin: auto;\n padding-top: $theme-space-small;\n text-align: center;\n\n @media screen and (min-width: 992px) {\n text-align: left;\n }\n\n .footer-logo {\n max-height: 60px;\n max-width: 140px;\n padding: $theme-space-small;\n padding-left: 0;\n padding-top: 0;\n }\n\n .footer-list {\n display: flex;\n justify-content: center;\n align-items: center;\n list-style: none;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n float: right;\n }\n\n li {\n display: inline-block;\n padding: $theme-space-small $theme-space-xsmall;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid $goodsam-gray-700;\n float: left;\n padding: 0;\n\n &:last-child {\n border-right: 0;\n }\n }\n\n a,\n button {\n font-size: $theme-type-size-xsmall;\n text-transform: uppercase;\n\n @media screen and (max-width: 768px) {\n display: block;\n padding: $theme-space-small;\n }\n\n @media screen and (min-width: 992px) {\n font-size: $theme-type-size-small;\n }\n }\n\n .dropup {\n background-clip: padding-box;\n border: none;\n font-size: $theme-type-size-small;\n list-style: none;\n padding-left: 5px;\n position: relative;\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n\n &:hover {\n .dropdown-menu {\n display: block;\n }\n }\n }\n\n .footer-dropup-toggle {\n background: none;\n border: 0;\n padding: 0;\n\n .fa-angle-up {\n /* @include li-icon ($fa-var-angle-up, $pseudo: before, $size: $theme-type-size-base, $color: $goodsam-gray-footer);\n padding-left: $theme-space-xsmall;\n padding-right: $theme-space-xsmall; */\n }\n }\n\n .dropdown-menu {\n background-color: #fff;\n border-radius: 4px;\n bottom: 100%;\n margin: 2px 0 0;\n min-width: 160px;\n padding: $theme-space-xsmall 0;\n position: absolute;\n right: 0;\n\n li {\n border-right: 0;\n float: none;\n text-align: left;\n\n @media screen and (max-width: 768px) {\n display: block;\n }\n\n a {\n color: $goodsam-gray;\n display: block;\n text-transform: none;\n\n &:hover {\n outline: 5px auto -webkit-focus-ring-color;\n outline-offset: -2px;\n }\n }\n }\n }\n }\n }\n}\n\n.footer-terms {\n display: flex;\n flex-direction: column;\n justify-content: center;\n align-items: center;\n padding: $theme-space-small 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n padding: 0;\n }\n\n > .row {\n padding-bottom: $theme-space-small;\n\n @media screen and (min-width: 992px) {\n padding-bottom: $theme-space-base;\n }\n\n &.footer-terms-order-1 {\n order: 1;\n }\n\n &.footer-terms-order-2 {\n order: 2;\n }\n }\n}\n\n.footer-bottom {\n @media screen and (min-width: 992px) {\n padding-top: $theme-space-small;\n }\n\n .footer-bottom-list-center {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n float: none;\n margin: 0 auto;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n display: inline;\n padding: 0 $theme-space-base;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid $goodsam-gray-700;\n padding: 0;\n\n &:first-child a {\n padding-left: 0;\n }\n\n &:last-child {\n border-right: 0;\n\n a {\n padding-right: 0;\n }\n }\n }\n\n a {\n display: inline-block;\n font-size: $theme-type-size-small;\n padding: $theme-space-small;\n\n @media screen and (min-width: 992px) {\n display: inline;\n font-size: $theme-type-size-xsmall;\n padding: 0 12px 0 $theme-space-small;\n }\n }\n }\n }\n}\n\n.copyright {\n color: $goodsam-gray-footer;\n font-size: $theme-type-size-base;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n margin-bottom: $theme-space-small;\n }\n}\n\n#gsFooterSocial,\n.gsFooterSocial {\n background: $goodsam-gray-200;\n padding: 0 calc($theme-space-small + $theme-space-xsmall);\n .footerSocialItems,\n #footerSocialItems {\n text-align: center;\n\n @media screen and (min-width: 767px) {\n text-align: left;\n }\n }\n\n .footerSocialItems ul,\n #footerSocialItems ul {\n list-style-type: none;\n margin: auto;\n padding-left: 0;\n\n li {\n display: inline;\n margin: 0 $theme-space-small;\n }\n }\n}\n","texts":{"custom.footer.col01.text.01":"Home","custom.footer.col01.url.01":"https://www.goodsam.com/","custom.footer.col01.text.02":"About Us","custom.footer.col01.url.02":"https://www.goodsam.com/about/","custom.footer.col01.text.03":"Contact Us","custom.footer.col01.url.03":"https://www.goodsam.com/contact","custom.footer.col01.text.04":"FAQ","custom.footer.col01.url.04":"https://www.goodsam.com/faq/","custom.footer.col01.text.05":"Site Map","custom.footer.col01.url.05":"https://www.goodsam.com/site-map.aspx","custom.footer.col02.text.01":"Code of Conduct","custom.footer.col02.url.01":"https://www.goodsam.com/code-of-conduct.aspx","custom.footer.col02.text.02":"Affiliate Program","custom.footer.col02.url.02":"https://www.goodsam.com/affiliate/","custom.footer.col02.text.03":"Become a Good Sam Campground","custom.footer.col02.url.03":"https://www.goodsamnetwork.com/","custom.footer.col02.text.04":"Good Sam Rewards Visa","custom.footer.col02.url.04":"https://www.goodsam.com/creditcard/","custom.footer.col02.text.05":"About Marcus Lemonis","custom.footer.col02.url.05":"https://www.goodsam.com/about-marcus-lemonis/","custom.footer.col03.text.01":"RV Sales","custom.footer.col03.url.01":"https://rv.campingworld.com/","custom.footer.col03.text.02":"RV Gear","custom.footer.col03.url.02":"https://www.campingworld.com/shop/","custom.footer.col03.text.03":"RV Maintenance & Repair","custom.footer.col03.url.03":"https://rv.campingworld.com/service/","custom.footer.col03.text.04":"Good Sam Membership & Services","custom.footer.col03.url.04":"https://www.goodsam.com/","custom.footer.col03.text.05":"Campground Solutions","custom.footer.col03.url.05":"https://campgroundsolutions.goodsam.com/","custom.footer.col04.text.01":"Helpful Articles and Tips","custom.footer.col04.url.01":"https://www.goodsam.com/article","custom.footer.col05.text.01":"Good Sam Apps","custom.footer.col05.url.01":"https://www.goodsam.com/rv-camping-apps/","custom.footer.col05.text.02":"Take Good Sam apps on your next RV Trip!","custom.footer.col05.url.02":"https://www.goodsam.com/rv-camping-apps/","custom.footer.col06.text.01":"Customer Service Phone Number:","custom.footer.col06.phone.number":"866-205-7451","custom.footer.col06.text.02":"Club contact number 866-205-7451","custom.footer.col06.url.02":"tel:866-205-7451","custom.footer.row01.logo.text":"Good Sam Home","custom.footer.row01.text.01":"Blog","custom.footer.row01.url.01":"http://blog.goodsam.com/","custom.footer.row01.text.02":"Careers","custom.footer.row01.url.02":"https://www.campingworldcareers.com/","custom.footer.row01.text.03":"Contact Us","custom.footer.row01.text.toggle":"Click to expand","custom.footer.row01.text.04":"Good Sam","custom.footer.row01.url.04":"https://www.goodsam.com/contact/","custom.footer.row01.text.05":"Camping World","custom.footer.row01.url.05":"https://www.campingworld.com/contact/","custom.footer.row01.text.06":"RV Sales","custom.footer.row01.url.06":"https://rv.campingworld.com/contact","custom.footer.row02.text.01":"Privacy Policy","custom.footer.row02.url.01":"https://www.goodsam.com/privacy-policy.aspx","custom.footer.row02.text.02":"California Privacy Rights","custom.footer.row02.url.02":"https://www.goodsam.com/privacy-policy.aspx#calinevada","custom.footer.row02.text.03":"Investor Relations","custom.footer.row02.url.03":"http://investor.campingworld.com","custom.footer.row02.text.04":"Terms of Use","custom.footer.row02.url.04":"https://www.goodsam.com/terms.aspx","custom.footer.row02.text.05":"Accessibility Commitment","custom.footer.row02.url.05":"https://www.goodsam.com/accessibility-commitment.aspx","custom.footer.row02.text.06":"Team Member Assistance","custom.footer.row02.url.06":"https://www.goodsam.com/helping-hand","custom.footer.social.facebook.text":"Facebook","custom.footer.social.facebook.url":"https://www.facebook.com/GoodSam","custom.footer.social.twitter.text":"Twitter","custom.footer.social.twitter.url":"https://twitter.com/GoodSam","custom.footer.social.youtube.text":"YouTube","custom.footer.social.youtube.url":"https://www.youtube.com/user/goodsamrvers","custom.footer.social.instagram.text":"Instagram","custom.footer.social.instagram.url":"https://www.instagram.com/goodsam/?hl=en","custom.footer.social.pinterest.text":"Pinterest","custom.footer.social.pinterest.url":"https://www.pinterest.com/goodsam/","custom-community-footer-copyright.text":"© {0} Good Sam Enterprises, LLC. All rights reserved."},"defaults":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"components":[{"id":"custom.widget.CustomFooter","form":null,"config":null,"props":[],"__typename":"Component"}],"grouping":"CUSTOM","__typename":"ComponentTemplate"},"properties":{"config":{"applicablePages":[],"description":"","fetchedContent":null,"__typename":"ComponentConfiguration"},"props":[],"__typename":"ComponentProperties"},"form":null,"__typename":"Component","localOverride":false},"globalCss":{"css":".custom_widget_CustomFooter_footer-wrapper_hp49n_21 {\n background: #474442;\n\n a {\n color: #dfdfdf;\n font-weight: 100;\n\n &:focus,\n &:hover {\n color: #dfdfdf;\n }\n }\n}\n.custom_widget_CustomFooter_sr-only_hp49n_34 {\n position: absolute;\n width: 0.0625rem;\n height: 0.0625rem;\n margin: -0.0625rem;\n padding: 0;\n overflow: hidden;\n clip: rect(0, 0, 0, 0);\n border: 0;\n}\n.custom_widget_CustomFooter_footer_hp49n_21 {\n line-height: 1.25rem;\n /* margin-left: auto;\n\tmargin-right: auto;\n\tpadding-left: $bootstrap-padding;\n\tpadding-right: $bootstrap-padding; */\n}\n.custom_widget_CustomFooter_container_hp49n_52 {\n margin-left: auto;\n margin-right: auto;\n max-width: 73.125rem;\n padding-left: 0.9375rem;\n padding-right: 0.9375rem;\n}\n.custom_widget_CustomFooter_row_hp49n_60 {\n /* HOTFIX - PSDS-32115 - Remove negative margins to fix mobile display */\n\n &::after {\n clear: both;\n }\n\n &::after,\n &::before {\n content: ' ';\n display: table;\n }\n}\n.custom_widget_CustomFooter_col_hp49n_74 {\n float: left;\n min-height: 0.0625rem;\n padding-left: 0.9375rem;\n padding-right: 0.9375rem;\n position: relative;\n}\n.custom_widget_CustomFooter_col-xs-10_hp49n_82,\n.custom_widget_CustomFooter_col-sm-10_hp49n_83 {\n width: 83.33333333%;\n}\n.custom_widget_CustomFooter_col-xs-12_hp49n_87,\n.custom_widget_CustomFooter_col-sm-4_hp49n_88,\n.custom_widget_CustomFooter_col-sm-12_hp49n_89,\n.custom_widget_CustomFooter_col-md-2_hp49n_90,\n.custom_widget_CustomFooter_col-md-8_hp49n_91,\n.custom_widget_CustomFooter_col-md-10_hp49n_92,\n.custom_widget_CustomFooter_col-md-12_hp49n_93,\n.custom_widget_CustomFooter_col-lg-2_hp49n_94,\n.custom_widget_CustomFooter_col-lg-8_hp49n_95,\n.custom_widget_CustomFooter_col-lg-12_hp49n_96 {\n width: 100%;\n}\n@media screen and (min-width: 767px) {\n .custom_widget_CustomFooter_col-md-2_hp49n_90 {\n width: 16.66666667%;\n }\n\n .custom_widget_CustomFooter_col-md-8_hp49n_91 {\n width: 66.66666667%;\n }\n\n .custom_widget_CustomFooter_col-md-10_hp49n_92 {\n width: 83.33333333%;\n }\n\n .custom_widget_CustomFooter_col-md-12_hp49n_93 {\n width: 100%;\n }\n}\n@media screen and (min-width: 992px) {\n .custom_widget_CustomFooter_col-lg-2_hp49n_94 {\n width: 16.66666667%;\n }\n\n .custom_widget_CustomFooter_col-lg-4_hp49n_123 {\n /* faking it; should be 33.33333333% */\n width: 25%;\n }\n\n .custom_widget_CustomFooter_col-lg-8_hp49n_95 {\n /* faking it; should be 66.66666667% */\n width: 75%;\n }\n\n .custom_widget_CustomFooter_col-lg-10_hp49n_133 {\n width: 83.33333333%;\n }\n\n .custom_widget_CustomFooter_col-lg-12_hp49n_96 {\n width: 100%;\n }\n}\n.custom_widget_CustomFooter_pull-left_hp49n_142 {\n float: left;\n width: 100%;\n\n @media screen and (min-width: 767px) {\n float: none;\n width: auto;\n }\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n}\n.custom_widget_CustomFooter_pad-bottom-20_hp49n_156 {\n padding-bottom: 1.25rem;\n}\n.custom_widget_CustomFooter_pad-top-20_hp49n_160 {\n padding-top: 1.25rem;\n}\n.custom_widget_CustomFooter_pad-top-30_hp49n_164 {\n padding-top: calc(0.9375rem * 2);\n}\n.custom_widget_CustomFooter_pad-top-40_hp49n_168 {\n @media screen and (min-width: 992px) {\n padding-top: 2.5rem;\n }\n}\n.custom_widget_CustomFooter_margin-left-20_hp49n_174 {\n @media screen and (min-width: 992px) {\n margin-left: 1.25rem;\n }\n}\n.custom_widget_CustomFooter_margin-top-20_hp49n_180 {\n @media screen and (min-width: 992px) {\n margin-top: 1.25rem;\n }\n}\n.custom_widget_CustomFooter_text-center_hp49n_186 {\n text-align: center;\n}\n.custom_widget_CustomFooter_text-right_hp49n_190 {\n text-align: right;\n}\n.custom_widget_CustomFooter_text-smaller_hp49n_194,\n.custom_widget_CustomFooter_text-small_hp49n_194 {\n font-size: 0.75rem;\n}\n.custom_widget_CustomFooter_text-large_hp49n_199 {\n font-size: 1.25rem;\n}\n.custom_widget_CustomFooter_footer-contact_hp49n_203 {\n p {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n .custom_widget_CustomFooter_text-small_hp49n_194 {\n @media screen and (max-width: 991px) {\n font-size: 1rem;\n }\n }\n }\n\n .custom_widget_CustomFooter_icon-gs-app_hp49n_221 {\n margin-right: 1.25rem;\n max-width: 2.375rem;\n padding-right: 0.125rem;\n padding-top: 0.125rem;\n\n @media screen and (min-width: 992px) {\n margin-left: 8.75rem;\n margin-right: 0;\n }\n }\n\n .custom_widget_CustomFooter_gsi-icon-phone_hp49n_233 {\n margin-bottom: -0.125rem;\n margin-right: 0.625rem;\n max-height: 1.25rem;\n width: 1.25rem;\n\n @media screen and (min-width: 992px) {\n margin-right: 0;\n }\n }\n}\n.custom_widget_CustomFooter_footer-link_hp49n_245 {\n a,\n button {\n color: #dfdfdf;\n padding: 0 0.75rem 0 0.625rem;\n }\n\n li:last-child a {\n padding-right: 0;\n }\n}\n.custom_widget_CustomFooter_footer-top-links_hp49n_257 {\n padding-left: 0;\n list-style: none;\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n margin-bottom: 0.625rem;\n font-size: 1rem;\n\n @media screen and (max-width: 480px) {\n flex-direction: column;\n }\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n margin-bottom: 1.25rem;\n padding: 0 1.25rem;\n\n @media screen and (min-width: 992px) {\n padding: 0;\n }\n }\n}\n.custom_widget_CustomFooter_footer-top_hp49n_257 {\n border-bottom: 2px solid #c7c7c7;\n display: block;\n margin: auto;\n padding-top: 0.625rem;\n text-align: center;\n\n @media screen and (min-width: 992px) {\n text-align: left;\n }\n\n .custom_widget_CustomFooter_footer-logo_hp49n_297 {\n max-height: 3.75rem;\n max-width: 8.75rem;\n padding: 0.625rem;\n padding-left: 0;\n padding-top: 0;\n }\n\n .custom_widget_CustomFooter_footer-list_hp49n_305 {\n display: flex;\n justify-content: center;\n align-items: center;\n list-style: none;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n float: right;\n }\n\n li {\n display: inline-block;\n padding: 0.625rem 0.3125rem;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid #666;\n float: left;\n padding: 0;\n\n &:last-child {\n border-right: 0;\n }\n }\n\n a,\n button {\n font-size: 0.75rem;\n text-transform: uppercase;\n\n @media screen and (max-width: 768px) {\n display: block;\n padding: 0.625rem;\n }\n\n @media screen and (min-width: 992px) {\n font-size: 0.875rem;\n }\n }\n\n .custom_widget_CustomFooter_dropup_hp49n_346 {\n background-clip: padding-box;\n border: none;\n font-size: 0.875rem;\n list-style: none;\n padding-left: 0.3125rem;\n position: relative;\n\n @media screen and (min-width: 992px) {\n float: left;\n }\n\n &:hover {\n .custom_widget_CustomFooter_dropdown-menu_hp49n_359 {\n display: block;\n }\n }\n }\n\n .custom_widget_CustomFooter_footer-dropup-toggle_hp49n_365 {\n background: none;\n border: 0;\n padding: 0;\n\n .custom_widget_CustomFooter_fa-angle-up_hp49n_370 {\n /* @include li-icon ($fa-var-angle-up, $pseudo: before, $size: $theme-type-size-base, $color: $goodsam-gray-footer);\n padding-left: $theme-space-xsmall;\n padding-right: $theme-space-xsmall; */\n }\n }\n\n .custom_widget_CustomFooter_dropdown-menu_hp49n_359 {\n background-color: #fff;\n border-radius: 0.25rem;\n bottom: 100%;\n margin: 0.125rem 0 0;\n min-width: 10rem;\n padding: 0.3125rem 0;\n position: absolute;\n right: 0;\n\n li {\n border-right: 0;\n float: none;\n text-align: left;\n\n @media screen and (max-width: 768px) {\n display: block;\n }\n\n a {\n color: #474442;\n display: block;\n text-transform: none;\n\n &:hover {\n outline: 5px auto -webkit-focus-ring-color;\n outline-offset: -2px;\n }\n }\n }\n }\n }\n }\n}\n.custom_widget_CustomFooter_footer-terms_hp49n_412 {\n display: flex;\n flex-direction: column;\n justify-content: center;\n align-items: center;\n padding: 0.625rem 0;\n\n @media screen and (min-width: 992px) {\n display: block;\n padding: 0;\n }\n\n > .custom_widget_CustomFooter_row_hp49n_60 {\n padding-bottom: 0.625rem;\n\n @media screen and (min-width: 992px) {\n padding-bottom: 1.25rem;\n }\n\n &.custom_widget_CustomFooter_footer-terms-order-1_hp49n_431 {\n order: 1;\n }\n\n &.custom_widget_CustomFooter_footer-terms-order-2_hp49n_435 {\n order: 2;\n }\n }\n}\n.custom_widget_CustomFooter_footer-bottom_hp49n_441 {\n @media screen and (min-width: 992px) {\n padding-top: 0.625rem;\n }\n\n .custom_widget_CustomFooter_footer-bottom-list-center_hp49n_446 {\n display: flex;\n flex-direction: row;\n justify-content: center;\n align-items: center;\n flex-wrap: wrap;\n float: none;\n margin: 0 auto;\n\n @media screen and (min-width: 992px) {\n display: block;\n }\n\n li {\n display: inline;\n padding: 0 1.25rem;\n\n @media screen and (min-width: 992px) {\n border-right: 1px solid #666;\n padding: 0;\n\n &:first-child a {\n padding-left: 0;\n }\n\n &:last-child {\n border-right: 0;\n\n a {\n padding-right: 0;\n }\n }\n }\n\n a {\n display: inline-block;\n font-size: 0.875rem;\n padding: 0.625rem;\n\n @media screen and (min-width: 992px) {\n display: inline;\n font-size: 0.75rem;\n padding: 0 0.75rem 0 0.625rem;\n }\n }\n }\n }\n}\n.custom_widget_CustomFooter_copyright_hp49n_495 {\n color: #dfdfdf;\n font-size: 1rem;\n margin-bottom: 0;\n\n @media screen and (min-width: 992px) {\n margin-bottom: 0.625rem;\n }\n}\n#custom_widget_CustomFooter_gsFooterSocial_hp49n_506,\n.custom_widget_CustomFooter_gsFooterSocial_hp49n_506 {\n background: #eaecef;\n padding: 0 calc(0.625rem + 0.3125rem);\n .custom_widget_CustomFooter_footerSocialItems_hp49n_509,\n #custom_widget_CustomFooter_footerSocialItems_hp49n_509 {\n text-align: center;\n\n @media screen and (min-width: 767px) {\n text-align: left;\n }\n }\n\n .custom_widget_CustomFooter_footerSocialItems_hp49n_509 ul,\n #custom_widget_CustomFooter_footerSocialItems_hp49n_509 ul {\n list-style-type: none;\n margin: auto;\n padding-left: 0;\n\n li {\n display: inline;\n margin: 0 0.625rem;\n }\n }\n}\n","tokens":{"footer-wrapper":"custom_widget_CustomFooter_footer-wrapper_hp49n_21","sr-only":"custom_widget_CustomFooter_sr-only_hp49n_34","footer":"custom_widget_CustomFooter_footer_hp49n_21","container":"custom_widget_CustomFooter_container_hp49n_52","row":"custom_widget_CustomFooter_row_hp49n_60","col":"custom_widget_CustomFooter_col_hp49n_74","col-xs-10":"custom_widget_CustomFooter_col-xs-10_hp49n_82","col-sm-10":"custom_widget_CustomFooter_col-sm-10_hp49n_83","col-xs-12":"custom_widget_CustomFooter_col-xs-12_hp49n_87","col-sm-4":"custom_widget_CustomFooter_col-sm-4_hp49n_88","col-sm-12":"custom_widget_CustomFooter_col-sm-12_hp49n_89","col-md-2":"custom_widget_CustomFooter_col-md-2_hp49n_90","col-md-8":"custom_widget_CustomFooter_col-md-8_hp49n_91","col-md-10":"custom_widget_CustomFooter_col-md-10_hp49n_92","col-md-12":"custom_widget_CustomFooter_col-md-12_hp49n_93","col-lg-2":"custom_widget_CustomFooter_col-lg-2_hp49n_94","col-lg-8":"custom_widget_CustomFooter_col-lg-8_hp49n_95","col-lg-12":"custom_widget_CustomFooter_col-lg-12_hp49n_96","col-lg-4":"custom_widget_CustomFooter_col-lg-4_hp49n_123","col-lg-10":"custom_widget_CustomFooter_col-lg-10_hp49n_133","pull-left":"custom_widget_CustomFooter_pull-left_hp49n_142","pad-bottom-20":"custom_widget_CustomFooter_pad-bottom-20_hp49n_156","pad-top-20":"custom_widget_CustomFooter_pad-top-20_hp49n_160","pad-top-30":"custom_widget_CustomFooter_pad-top-30_hp49n_164","pad-top-40":"custom_widget_CustomFooter_pad-top-40_hp49n_168","margin-left-20":"custom_widget_CustomFooter_margin-left-20_hp49n_174","margin-top-20":"custom_widget_CustomFooter_margin-top-20_hp49n_180","text-center":"custom_widget_CustomFooter_text-center_hp49n_186","text-right":"custom_widget_CustomFooter_text-right_hp49n_190","text-smaller":"custom_widget_CustomFooter_text-smaller_hp49n_194","text-small":"custom_widget_CustomFooter_text-small_hp49n_194","text-large":"custom_widget_CustomFooter_text-large_hp49n_199","footer-contact":"custom_widget_CustomFooter_footer-contact_hp49n_203","icon-gs-app":"custom_widget_CustomFooter_icon-gs-app_hp49n_221","gsi-icon-phone":"custom_widget_CustomFooter_gsi-icon-phone_hp49n_233","footer-link":"custom_widget_CustomFooter_footer-link_hp49n_245","footer-top-links":"custom_widget_CustomFooter_footer-top-links_hp49n_257","footer-top":"custom_widget_CustomFooter_footer-top_hp49n_257","footer-logo":"custom_widget_CustomFooter_footer-logo_hp49n_297","footer-list":"custom_widget_CustomFooter_footer-list_hp49n_305","dropup":"custom_widget_CustomFooter_dropup_hp49n_346","dropdown-menu":"custom_widget_CustomFooter_dropdown-menu_hp49n_359","footer-dropup-toggle":"custom_widget_CustomFooter_footer-dropup-toggle_hp49n_365","fa-angle-up":"custom_widget_CustomFooter_fa-angle-up_hp49n_370","footer-terms":"custom_widget_CustomFooter_footer-terms_hp49n_412","footer-terms-order-1":"custom_widget_CustomFooter_footer-terms-order-1_hp49n_431","footer-terms-order-2":"custom_widget_CustomFooter_footer-terms-order-2_hp49n_435","footer-bottom":"custom_widget_CustomFooter_footer-bottom_hp49n_441","footer-bottom-list-center":"custom_widget_CustomFooter_footer-bottom-list-center_hp49n_446","copyright":"custom_widget_CustomFooter_copyright_hp49n_495","gsFooterSocial":"custom_widget_CustomFooter_gsFooterSocial_hp49n_506","footerSocialItems":"custom_widget_CustomFooter_footerSocialItems_hp49n_509"}},"form":null},"localOverride":false},"CachedAsset:text:en_US-components/community/Breadcrumb-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Breadcrumb-1741694506000","value":{"navLabel":"Breadcrumbs","dropdown":"Additional parent page navigation"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBanner-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBanner-1741694506000","value":{"messageMarkedAsSpam":"This post has been marked as spam","messageMarkedAsSpam@board:TKB":"This article has been marked as spam","messageMarkedAsSpam@board:BLOG":"This post has been marked as spam","messageMarkedAsSpam@board:FORUM":"This discussion has been marked as spam","messageMarkedAsSpam@board:OCCASION":"This event has been marked as spam","messageMarkedAsSpam@board:IDEA":"This idea has been marked as spam","manageSpam":"Manage Spam","messageMarkedAsAbuse":"This post has been marked as abuse","messageMarkedAsAbuse@board:TKB":"This article has been marked as abuse","messageMarkedAsAbuse@board:BLOG":"This post has been marked as abuse","messageMarkedAsAbuse@board:FORUM":"This discussion has been marked as abuse","messageMarkedAsAbuse@board:OCCASION":"This event has been marked as abuse","messageMarkedAsAbuse@board:IDEA":"This idea has been marked as abuse","preModCommentAuthorText":"This comment will be published as soon as it is approved","preModCommentModeratorText":"This comment is awaiting moderation","messageMarkedAsOther":"This post has been rejected due to other reasons","messageMarkedAsOther@board:TKB":"This article has been rejected due to other reasons","messageMarkedAsOther@board:BLOG":"This post has been rejected due to other reasons","messageMarkedAsOther@board:FORUM":"This discussion has been rejected due to other reasons","messageMarkedAsOther@board:OCCASION":"This event has been rejected due to other reasons","messageMarkedAsOther@board:IDEA":"This idea has been rejected due to other reasons","messageArchived":"This post was archived on {date}","relatedUrl":"View Related Content","relatedContentText":"Showing related content","archivedContentLink":"View Archived Content"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeActionButtonWidget-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeActionButtonWidget-1741694506000","value":{"defaultActionButtonTitle":"Start a Conversation","actionButton.grouphub.startDiscussion":"Start a Discussion","actionButton.title@board:FORUM":"Start a Discussion","actionButton.title@board:BLOG":"Create a Blog Post","actionButton.title@board:TKB":"Create an Article","actionButton.title@board:OCCASION":"Create an Event","actionButton.title@board:IDEA":"Suggest an Idea","joinGroupHub":"Join Group","join.successHeader":"Welcome","join.successMessage":"You are now a member of this group and are subscribed to updates.","errorMessage":"An unidentified problem occurred during the action you took. Please try again later.","errorHeader":"Error - Action Failed"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeInformationWidget-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeInformationWidget-1741694506000","value":{"WidgetTitle":"About {title}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/RelatedContentWidget-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/RelatedContentWidget-1741694506000","value":{"title":"Related Content","emptyDescription":"No content to show"},"localOverride":false},"CachedAsset:text:en_US-components/community/FooterWidget-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/FooterWidget-1741694506000","value":{"homeLink":"Community Home","topOfPage":"Top of Page","buildHash":"Build Hash:","buildNumber":"Build Number:","buildTime":"Build Time:","privacyPolicy":"Privacy Policy","helpLink":"Help"},"localOverride":false},"Category:category:RVTalk":{"__typename":"Category","id":"category:RVTalk","categoryPolicies":{"__typename":"CategoryPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"entityType":"CATEGORY","displayId":"RVTalk","nodeType":"category","depth":1,"title":"Forums","shortTitle":"Forums"},"Forum:board:GetSupportAskQuestions":{"__typename":"Forum","id":"board:GetSupportAskQuestions","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Forum:board:CommunityFeedback":{"__typename":"Forum","id":"board:CommunityFeedback","forumPolicies":{"__typename":"ForumPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Blog:board:Announcements_Blog":{"__typename":"Blog","id":"board:Announcements_Blog","blogPolicies":{"__typename":"BlogPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}},"boardPolicies":{"__typename":"BoardPolicies","canReadNode":{"__typename":"PolicyResult","failureReason":null}}},"Rank:rank:19":{"__typename":"Rank","id":"rank:19","position":34,"name":"Explorer II","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:402424":{"__typename":"User","id":"user:402424","uid":402424,"login":"Shadowwalker","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-11-06T18:12:20.279-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-6.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":6,"kudosGivenCount":0,"kudosReceivedCount":1,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":2,"entityType":"USER","eventPath":"community:feyqc97479/user:402424"},"GroupHub:grouphub:TruckCamperGroup":{"__typename":"GroupHub","id":"grouphub:TruckCamperGroup","entityType":"GROUP_HUB","displayId":"TruckCamperGroup","nodeType":"grouphub","depth":2,"title":"Truck Camper Group","shortTitle":"Truck Camper Group"},"Forum:board:TruckCamperGroupforum-board":{"__typename":"Forum","id":"board:TruckCamperGroupforum-board","entityType":"FORUM","displayId":"TruckCamperGroupforum-board","nodeType":"board","depth":3,"conversationStyle":"FORUM","title":"Truck Camper Group","shortTitle":"Forum","parent":{"__ref":"GroupHub:grouphub:TruckCamperGroup"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":null,"description":"","eventPath":"grouphub:TruckCamperGroup/category:TRAVELCENTER/community:feyqc97479board:TruckCamperGroupforum-board/"},"ForumTopicMessage:message:3681405":{"__typename":"ForumTopicMessage","uid":3681405,"subject":"Truck camper match","id":"message:3681405","revisionNum":1,"repliesCount":10,"author":{"__ref":"User:user:402424"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TruckCamperGroupforum-board"},"conversation":{"__ref":"Conversation:conversation:3681405"},"moderationData":{"__ref":"ModerationData:moderation_data:3681405"},"postTime":"2024-11-06T18:32:49.536-08:00","lastPublishTime":"2024-11-06T18:32:49.536-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":739},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"grouphub:TruckCamperGroup/category:TRAVELCENTER/community:feyqc97479board:TruckCamperGroupforum-board/message:3681405"},"Conversation:conversation:3681405":{"__typename":"Conversation","id":"conversation:3681405","solved":true,"topic":{"__ref":"ForumTopicMessage:message:3681405"},"lastPostingActivityTime":"2024-11-14T17:38:31.110-08:00","lastPostTime":"2024-11-14T17:38:31.110-08:00"},"ModerationData:moderation_data:3681405":{"__typename":"ModerationData","id":"moderation_data:3681405","status":"UNMODERATED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3681405":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3681405","relatedMessage":{"__ref":"ForumTopicMessage:message:3681405"}},"Rank:rank:34":{"__typename":"Rank","id":"rank:34","position":19,"name":"Navigator III","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:348350":{"__typename":"User","id":"user:348350","uid":348350,"login":"MORSNOW","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2013-10-29T21:57:45.000-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/images/dS0zNDgzNTAtMmZmbVE0?image-coordinates=16%2C0%2C115%2C99"},"rank":{"__ref":"Rank:rank:34"},"messagesCount":877,"kudosGivenCount":449,"kudosReceivedCount":70,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":3,"entityType":"USER","eventPath":"community:feyqc97479/user:348350"},"ForumTopicMessage:message:3635184":{"__typename":"ForumTopicMessage","uid":3635184,"subject":"New Truck Camper Forum Comments","id":"message:3635184","revisionNum":3,"repliesCount":63,"author":{"__ref":"User:user:348350"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TruckCamperGroupforum-board"},"conversation":{"__ref":"Conversation:conversation:3635184"},"moderationData":{"__ref":"ModerationData:moderation_data:3635184"},"postTime":"2023-11-18T07:34:33.917-08:00","lastPublishTime":"2023-11-18T07:39:51.259-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":7614},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"grouphub:TruckCamperGroup/category:TRAVELCENTER/community:feyqc97479board:TruckCamperGroupforum-board/message:3635184"},"Conversation:conversation:3635184":{"__typename":"Conversation","id":"conversation:3635184","solved":true,"topic":{"__ref":"ForumTopicMessage:message:3635184"},"lastPostingActivityTime":"2024-08-13T17:29:06.990-07:00","lastPostTime":"2024-08-13T17:29:06.990-07:00"},"ModerationData:moderation_data:3635184":{"__typename":"ModerationData","id":"moderation_data:3635184","status":"UNMODERATED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3635184":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3635184","relatedMessage":{"__ref":"ForumTopicMessage:message:3635184"}},"Rank:rank:40":{"__typename":"Rank","id":"rank:40","position":31,"name":"Explorer III","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:1368":{"__typename":"User","id":"user:1368","uid":1368,"login":"egarant","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2003-12-01T12:03:55.000-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-10.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:40"},"messagesCount":542,"kudosGivenCount":0,"kudosReceivedCount":5,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:1368"},"ForumTopicMessage:message:3680411":{"__typename":"ForumTopicMessage","uid":3680411,"subject":"Truck Camper Tie Downs","id":"message:3680411","revisionNum":1,"repliesCount":6,"author":{"__ref":"User:user:1368"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TruckCamperGroupforum-board"},"conversation":{"__ref":"Conversation:conversation:3680411"},"moderationData":{"__ref":"ModerationData:moderation_data:3680411"},"postTime":"2024-09-14T12:40:59.603-07:00","lastPublishTime":"2024-09-14T12:40:59.603-07:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":786},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"grouphub:TruckCamperGroup/category:TRAVELCENTER/community:feyqc97479board:TruckCamperGroupforum-board/message:3680411"},"Conversation:conversation:3680411":{"__typename":"Conversation","id":"conversation:3680411","solved":true,"topic":{"__ref":"ForumTopicMessage:message:3680411"},"lastPostingActivityTime":"2024-09-17T13:52:14.626-07:00","lastPostTime":"2024-09-17T13:52:14.626-07:00"},"ModerationData:moderation_data:3680411":{"__typename":"ModerationData","id":"moderation_data:3680411","status":"UNMODERATED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3680411":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3680411","relatedMessage":{"__ref":"ForumTopicMessage:message:3680411"}},"User:user:399762":{"__typename":"User","id":"user:399762","uid":399762,"login":"WrinkledPenny","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-03-08T04:42:09.726-08:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-3.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:19"},"messagesCount":5,"kudosGivenCount":6,"kudosReceivedCount":2,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:399762"},"ForumTopicMessage:message:3669520":{"__typename":"ForumTopicMessage","uid":3669520,"subject":"Truck camper towing a boat","id":"message:3669520","revisionNum":1,"repliesCount":8,"author":{"__ref":"User:user:399762"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TruckCamperGroupforum-board"},"conversation":{"__ref":"Conversation:conversation:3669520"},"moderationData":{"__ref":"ModerationData:moderation_data:3669520"},"postTime":"2024-03-08T06:59:55.870-08:00","lastPublishTime":"2024-03-08T06:59:55.870-08:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":2190},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"grouphub:TruckCamperGroup/category:TRAVELCENTER/community:feyqc97479board:TruckCamperGroupforum-board/message:3669520"},"Conversation:conversation:3669520":{"__typename":"Conversation","id":"conversation:3669520","solved":true,"topic":{"__ref":"ForumTopicMessage:message:3669520"},"lastPostingActivityTime":"2024-03-12T21:07:10.187-07:00","lastPostTime":"2024-03-12T21:07:10.187-07:00"},"ModerationData:moderation_data:3669520":{"__typename":"ModerationData","id":"moderation_data:3669520","status":"UNMODERATED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3669520":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3669520","relatedMessage":{"__ref":"ForumTopicMessage:message:3669520"}},"Rank:rank:20":{"__typename":"Rank","id":"rank:20","position":36,"name":"Explorer","color":"333333","icon":null,"rankStyle":"TEXT"},"User:user:401245":{"__typename":"User","id":"user:401245","uid":401245,"login":"Kalob3211","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2024-07-08T22:02:30.945-07:00","confirmEmailStatus":null,"registrationAccessLevel":null,"ssoRegistrationFields":[]},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-5.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:20"},"messagesCount":5,"kudosGivenCount":0,"kudosReceivedCount":0,"kudosWeight":1,"ssoId":null,"followersCount":null,"solutionsCount":0,"entityType":"USER","eventPath":"community:feyqc97479/user:401245"},"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi0xNC01NjBpRjZEQTJBOEZFMzZFOUFBMw\"}":{"__typename":"AssociatedImage","url":"https://community.goodsam.com/t5/s/feyqc97479/images/bi0xNC01NjBpRjZEQTJBOEZFMzZFOUFBMw","mimeType":"image/png"},"Forum:board:TechnicalIssues":{"__typename":"Forum","id":"board:TechnicalIssues","entityType":"FORUM","displayId":"TechnicalIssues","nodeType":"board","depth":2,"conversationStyle":"FORUM","title":"Technical Issues","shortTitle":"Technical Issues","parent":{"__ref":"Category:category:RVTalk"},"userContext":{"__typename":"NodeUserContext","canAddAttachments":false,"canUpdateNode":false,"canPostMessages":false,"isSubscribed":false},"avatar":{"__ref":"AssociatedImage:{\"url\":\"https://community.goodsam.com/t5/s/feyqc97479/images/bi0xNC01NjBpRjZEQTJBOEZFMzZFOUFBMw\"}"},"description":"Having RV issues? Connect with others who have been in your shoes.","eventPath":"category:RVTalk/community:feyqc97479board:TechnicalIssues/"},"ForumTopicMessage:message:3678590":{"__typename":"ForumTopicMessage","uid":3678590,"subject":"Lights in camper are dimming randomly","id":"message:3678590","revisionNum":1,"repliesCount":11,"author":{"__ref":"User:user:401245"},"depth":0,"hasGivenKudo":false,"board":{"__ref":"Forum:board:TechnicalIssues"},"conversation":{"__ref":"Conversation:conversation:3678590"},"moderationData":{"__ref":"ModerationData:moderation_data:3678590"},"postTime":"2024-07-08T22:09:21.998-07:00","lastPublishTime":"2024-07-08T22:09:21.998-07:00","readOnly":false,"metrics":{"__typename":"MessageMetrics","views":1361},"placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"entityType":"FORUM_TOPIC","eventPath":"category:RVTalk/community:feyqc97479board:TechnicalIssues/message:3678590"},"Conversation:conversation:3678590":{"__typename":"Conversation","id":"conversation:3678590","solved":true,"topic":{"__ref":"ForumTopicMessage:message:3678590"},"lastPostingActivityTime":"2024-07-10T17:24:59.467-07:00","lastPostTime":"2024-07-10T17:24:59.467-07:00"},"ModerationData:moderation_data:3678590":{"__typename":"ModerationData","id":"moderation_data:3678590","status":"UNMODERATED","rejectReason":null},"RelatedContentMessage:RelatedContentMessage:3678590":{"__typename":"RelatedContentMessage","id":"RelatedContentMessage:3678590","relatedMessage":{"__ref":"ForumTopicMessage:message:3678590"}},"QueryVariables:TopicReplyList:message:3583102:1":{"__typename":"QueryVariables","id":"TopicReplyList:message:3583102:1","value":{"id":"message:3583102","first":10,"after":"MjUuMnwyLjF8aXwxMHwzOTowfGludCwzNTgzMTEzLDM1ODMxMDQ","sorts":{"postTime":{"direction":"DESC"}},"repliesFirst":3,"repliesFirstDepthThree":1,"repliesSorts":{"postTime":{"direction":"DESC"}},"useAvatar":true,"useAuthorLogin":true,"useAuthorRank":true,"useBody":true,"useKudosCount":true,"useTimeToRead":false,"useMedia":false,"useReadOnlyIcon":false,"useRepliesCount":true,"useSearchSnippet":false,"useAcceptedSolutionButton":true,"useSolvedBadge":false,"useAttachments":false,"attachmentsFirst":5,"useTags":true,"useNodeAncestors":false,"useUserHoverCard":false,"useNodeHoverCard":false,"useModerationStatus":true,"usePreviewSubjectModal":false,"useMessageStatus":true}},"ROOT_MUTATION":{"__typename":"Mutation"},"CachedAsset:text:en_US-components/community/Navbar-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/Navbar-1741694506000","value":{"community":"Community Home","inbox":"Inbox","manageContent":"Manage Content","tos":"Terms of Service","forgotPassword":"Forgot Password","themeEditor":"Theme Editor","edit":"Edit Navigation Bar","skipContent":"Skip to content","rv-owners-link":"RV Owner Groups","groups-link":"Groups","migrated-link-7":"Good Sam Home ","community-feedback-link":"Community Feedback","migrated-link-8":"My Rewards","Common-community-feedback-link":"Community Feedback","migrated-link-1":"Groups","customer-support-link-1":"Customer Support","Common-announcements_blog-link":"Announcements","customer-support-link":"Resources","Common-get-support-ask-questions-link":"Customer Support","Common-external-link":"Events","migrated-link-0":"Forums","migrated-link-3":"Resources","announcements_blog-link":"Announcements","r-v-t-e-c-h-link":"Test ","Common-admin-mods-private-link":"Admin & Mods (Private)","fifth-wheelsforum-board-link":"Fifth Wheels Owners","events-link":"Events","external-link":"Good Sam Home"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarHamburgerDropdown-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarHamburgerDropdown-1741694506000","value":{"hamburgerLabel":"Side Menu"},"localOverride":false},"CachedAsset:text:en_US-components/community/BrandLogo-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/BrandLogo-1741694506000","value":{"logoAlt":"Khoros","themeLogoAlt":"Brand Logo"},"localOverride":false},"CachedAsset:text:en_US-components/community/NavbarTextLinks-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarTextLinks-1741694506000","value":{"more":"More"},"localOverride":false},"CachedAsset:text:en_US-components/search/SpotlightSearchIcon-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/search/SpotlightSearchIcon-1741694506000","value":{"search":"Search"},"localOverride":false},"CachedAsset:text:en_US-components/authentication/AuthenticationLink-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/authentication/AuthenticationLink-1741694506000","value":{"title.login":"Sign In or Register","title.registration":"Register","title.forgotPassword":"Forgot Password","title.multiAuthLogin":"Sign In or Register"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLink-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLink-1741694506000","value":{"place":"Place {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewStandard-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewStandard-1741694506000","value":{"anonymous":"Anonymous","author":"{messageAuthorLogin}","authorBy":"{messageAuthorLogin}","board":"{messageBoardTitle}","replyToUser":" to {parentAuthor}","showMoreReplies":"Show More","replyText":"Reply","repliesText":"Replies","markedAsSolved":"Marked as Solved","movedMessagePlaceholder.BLOG":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.TKB":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.FORUM":"{count, plural, =0 {This reply has been} other {These replies have been} }","movedMessagePlaceholder.IDEA":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholder.OCCASION":"{count, plural, =0 {This comment has been} other {These comments have been} }","movedMessagePlaceholderUrlText":"moved.","messageStatus":"Status: ","statusChanged":"Status changed: {previousStatus} to {currentStatus}","statusAdded":"Status added: {status}","statusRemoved":"Status removed: {status}","labelExpand":"expand replies","labelCollapse":"collapse replies","unhelpfulReason.reason1":"Content is outdated","unhelpfulReason.reason2":"Article is missing information","unhelpfulReason.reason3":"Content is for a different Product","unhelpfulReason.reason4":"Doesn't match what I was searching for"},"localOverride":false},"CachedAsset:text:en_US-components/messages/ThreadedReplyList-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/ThreadedReplyList-1741694506000","value":{"title":"{count, plural, one{# Reply} other{# Replies}}","title@board:BLOG":"{count, plural, one{# Comment} other{# Comments}}","title@board:TKB":"{count, plural, one{# Comment} other{# Comments}}","title@board:IDEA":"{count, plural, one{# Comment} other{# Comments}}","title@board:OCCASION":"{count, plural, one{# Comment} other{# Comments}}","noRepliesTitle":"No Replies","noRepliesTitle@board:BLOG":"No Comments","noRepliesTitle@board:TKB":"No Comments","noRepliesTitle@board:IDEA":"No Comments","noRepliesTitle@board:OCCASION":"No Comments","noRepliesDescription":"Be the first to reply","noRepliesDescription@board:BLOG":"Be the first to comment","noRepliesDescription@board:TKB":"Be the first to comment","noRepliesDescription@board:IDEA":"Be the first to comment","noRepliesDescription@board:OCCASION":"Be the first to comment","messageReadOnlyAlert:BLOG":"Comments have been turned off for this post","messageReadOnlyAlert:TKB":"Comments have been turned off for this article","messageReadOnlyAlert:IDEA":"Comments have been turned off for this idea","messageReadOnlyAlert:FORUM":"Replies have been turned off for this discussion","messageReadOnlyAlert:OCCASION":"Comments have been turned off for this event"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyCallToAction-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyCallToAction-1741694506000","value":{"leaveReply":"Leave a reply...","leaveReply@board:BLOG@message:root":"Leave a comment...","leaveReply@board:TKB@message:root":"Leave a comment...","leaveReply@board:IDEA@message:root":"Leave a comment...","leaveReply@board:OCCASION@message:root":"Leave a comment...","repliesTurnedOff.FORUM":"Replies are turned off for this topic","repliesTurnedOff.BLOG":"Comments are turned off for this topic","repliesTurnedOff.TKB":"Comments are turned off for this topic","repliesTurnedOff.IDEA":"Comments are turned off for this topic","repliesTurnedOff.OCCASION":"Comments are turned off for this topic","infoText":"Stop poking me!"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/QueryHandler-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/QueryHandler-1741694506000","value":{"title":"Query Handler"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/common/BuildInformation-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/common/BuildInformation-1741694506000","value":{"buildHash":"Build Hash: {buildHash}","buildNumber":"Build Number: {buildNumber}","buildTime":"Build Time: {buildTime}"},"localOverride":false},"CachedAsset:text:en_US-components/community/KhorosLogo-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/KhorosLogo-1741694506000","value":{"alt":"Powered By Khoros"},"localOverride":false},"User:user:315313":{"__typename":"User","id":"user:315313","uid":315313,"login":"jimh406","biography":null,"registrationData":{"__typename":"RegistrationData","status":null,"registrationTime":"2006-06-11T17:07:12.000-07:00"},"deleted":false,"email":"","avatar":{"__typename":"UserAvatar","url":"https://community.goodsam.com/t5/s/feyqc97479/m_assets/avatars/default/avatar-1.svg?time=1737155183000"},"rank":{"__ref":"Rank:rank:40"},"entityType":"USER","eventPath":"community:feyqc97479/user:315313"},"ModerationData:moderation_data:3583103":{"__typename":"ModerationData","id":"moderation_data:3583103","status":"APPROVED","rejectReason":null,"isReportedAbuse":false,"rejectUser":null,"rejectTime":null,"rejectActorType":null},"ForumReplyMessage:message:3583103":{"__typename":"ForumReplyMessage","author":{"__ref":"User:user:315313"},"id":"message:3583103","revisionNum":1,"uid":3583103,"depth":1,"hasGivenKudo":false,"subscribed":false,"board":{"__ref":"Forum:board:TravelTrailerforum-board"},"parent":{"__ref":"ForumTopicMessage:message:3583102"},"conversation":{"__ref":"Conversation:conversation:3583102"},"subject":"Re: DIY Slide In Camper questions","moderationData":{"__ref":"ModerationData:moderation_data:3583103"},"body":"Your biggest issue is the truck. DIY probably means heavy and that’s not where your truck shines. I think I’d go with a popup style construction. That reduce the drag and weight.","body@stripHtml({\"removeProcessingText\":false,\"removeSpoilerMarkup\":false,\"removeTocMarkup\":false,\"truncateLength\":200})@stringLength":"181","kudosSumWeight":0,"repliesCount":0,"postTime":"2022-06-26T16:30:30.000-07:00","lastPublishTime":"2022-06-26T16:30:30.000-07:00","metrics":{"__typename":"MessageMetrics","views":880},"visibilityScope":"PUBLIC","placeholder":false,"originalMessageForPlaceholder":null,"isEscalated":null,"solution":false,"entityType":"FORUM_REPLY","eventPath":"grouphub:TravelTrailer/category:TRAVELCENTER/community:feyqc97479board:TravelTrailerforum-board/message:3583102/message:3583103","replies":{"__typename":"MessageConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"readOnly":false,"editFrozen":false,"body@stringLength":"181","rawBody":"Your biggest issue is the truck. DIY probably means heavy and that’s not where your truck shines. I think I’d go with a popup style construction. That reduce the drag and weight.","images":{"__typename":"AssociatedImageConnection","edges":[],"totalCount":0,"pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null}},"attachments":{"__typename":"AttachmentConnection","pageInfo":{"__typename":"PageInfo","hasNextPage":false,"endCursor":null,"hasPreviousPage":false,"startCursor":null},"edges":[]},"timeToRead":1,"currentRevision":{"__ref":"Revision:revision:3583103_1"},"latestVersion":null,"messagePolicies":{"__typename":"MessagePolicies","canModerateSpamMessage":{"__typename":"PolicyResult","failureReason":{"__typename":"FailureReason","message":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","key":"error.lithium.policies.feature.moderation_spam.action.moderate_entity.allowed.accessDenied","args":[]}}},"customFields":[]},"CachedAsset:text:en_US-components/community/NavbarDropdownToggle-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/community/NavbarDropdownToggle-1741694506000","value":{"ariaLabelClosed":"Press the down arrow to open the menu"},"localOverride":false},"CachedAsset:text:en_US-components/messages/EscalatedMessageBanner-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/EscalatedMessageBanner-1741694506000","value":{"escalationMessage":"Escalated to Salesforce by {username} on {date}","viewDetails":"View Details","modalTitle":"Case Details","escalatedBy":"Escalated by: ","escalatedOn":"Escalated on: ","caseNumber":"Case Number: ","status":"Status: ","lastUpdateDate":"Last Update: ","automaticEscalation":"automatic escalation","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-components/users/UserLink-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/users/UserLink-1741694506000","value":{"authorName":"View Profile: {author}","anonymous":"Anonymous"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/users/UserRank-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserRank-1741694506000","value":{"rankName":"{rankName}","userRank":"Author rank {rankName}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageTime-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageTime-1741694506000","value":{"postTime":"Published: {time}","lastPublishTime":"Last Update: {time}","conversation.lastPostingActivityTime":"Last posting activity time: {time}","conversation.lastPostTime":"Last post time: {time}","moderationData.rejectTime":"Rejected time: {time}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSolvedBadge-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSolvedBadge-1741694506000","value":{"solved":"Solved"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageSubject-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageSubject-1741694506000","value":{"noSubject":"(no subject)"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageBody-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageBody-1741694506000","value":{"showMessageBody":"Show More","mentionsErrorTitle":"{mentionsType, select, board {Board} user {User} message {Message} other {}} No Longer Available","mentionsErrorMessage":"The {mentionsType} you are trying to view has been removed from the community.","videoProcessing":"Video is being processed. Please try again in a few minutes.","bannerTitle":"Video provider requires cookies to play the video. Accept to continue or {url} it directly on the provider's site.","buttonTitle":"Accept","urlText":"watch"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageCustomFields-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageCustomFields-1741694506000","value":{"CustomField.default.label":"Value of {name}"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageReplyButton-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageReplyButton-1741694506000","value":{"repliesCount":"{count}","title":"Reply","title@board:BLOG@message:root":"Comment","title@board:TKB@message:root":"Comment","title@board:IDEA@message:root":"Comment","title@board:OCCASION@message:root":"Comment"},"localOverride":false},"CachedAsset:text:en_US-components/messages/AcceptedSolutionButton-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/AcceptedSolutionButton-1741694506000","value":{"accept":"Mark as Solution","accepted":"Marked as Solution","errorHeader":"Error!","errorAdd":"There was an error marking as solution.","errorRemove":"There was an error unmarking as solution.","solved":"Solved","topicAlreadySolvedErrorTitle":"Solution Already Exists","topicAlreadySolvedErrorDesc":"Refresh the browser to view the existing solution"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeView/NodeViewCard-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeView/NodeViewCard-1741694506000","value":{"title":"{nodeTitle} ","creationDate":"Created: {creationDate}","ownedBy":"Owned by: {owners}{text}","showOwnerListText":", and {ownersCount} more","unreadCount":"{count} unread","nodeViewDrawerBtn":"Node view drawer for {place}","drawerActionTooltip":"Show category children"},"localOverride":false},"CachedAsset:text:en_US-components/messages/MessageView/MessageViewInline-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/messages/MessageView/MessageViewInline-1741694506000","value":{"bylineAuthor":"{bylineAuthor}","bylineBoard":"{bylineBoard}","anonymous":"Anonymous","place":"Place {bylineBoard}","gotoParent":"Go to parent {name}"},"localOverride":false},"Revision:revision:3583103_1":{"__typename":"Revision","id":"revision:3583103_1","lastEditTime":"2022-06-26T16:30:30.000-07:00"},"CachedAsset:text:en_US-shared/client/components/users/UserAvatar-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/users/UserAvatar-1741694506000","value":{"altText":"{login}'s avatar","altTextGeneric":"User's avatar"},"localOverride":false},"CachedAsset:text:en_US-shared/client/components/ranks/UserRankLabel-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-shared/client/components/ranks/UserRankLabel-1741694506000","value":{"altTitle":"Icon for {rankName} rank"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeTopicsCount-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeTopicsCount-1741694506000","value":{"topicCount":"{count}","topicCountWithNeutralLabel@board:OCCASION":"{count, plural, one{# Event} other{# Events}}","topicCountWithNeutralLabel":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:FORUM":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:BLOG":"{count, plural, one{# Post} other{# Posts}}","topicCount@board:CONTEST":"{count, plural, one{# Entry} other{# Entries}}","topicCount@board:GROUP":"{count, plural, one{# Topic} other{# Topics}}","topicCount@board:IDEA":"{count, plural, one{# Idea} other{# Ideas}}","topicCount@board:QANDA":"{count, plural, one{# Question} other{# Questions}}","topicCount@board:TKB":"{count, plural, one{# Article} other{# Articles}}","topicCount@board:OCCASION":"{count, plural, one{# Event} other{# Events}}","title":"{count, plural,one { Post} other{ Posts}}"},"localOverride":false},"CachedAsset:text:en_US-components/nodes/NodeLatestActivityTime-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/nodes/NodeLatestActivityTime-1741694506000","value":{"title":"Latest Activity: {latestActivityTime}","updatedAt":"Updated {latestActivityTime}","noActivity":"No activity yet"},"localOverride":false},"CachedAsset:text:en_US-components/tags/TagView/TagViewChip-1741694506000":{"__typename":"CachedAsset","id":"text:en_US-components/tags/TagView/TagViewChip-1741694506000","value":{"tagLabelName":"Tag name {tagName}"},"localOverride":false}}}},"page":"/forums/ForumMessagePage/ForumMessagePage","query":{"after":"MjUuMnwyLjF8aXwxMHwzOTowfGludCwzNTgzMTEzLDM1ODMxMDQ","boardId":"traveltrailerforum-board","messageSubject":"diy-slide-in-camper-questions","messageId":"3583102"},"buildId":"q_bLpq2mflH0BeZigxpj6","runtimeConfig":{"buildInformationVisible":false,"logLevelApp":"info","logLevelMetrics":"info","openTelemetryClientEnabled":false,"openTelemetryConfigName":"campingworld","openTelemetryServiceVersion":"25.2.0","openTelemetryUniverse":"prod","openTelemetryCollector":"http://localhost:4318","openTelemetryRouteChangeAllowedTime":"5000","apolloDevToolsEnabled":false,"inboxMuteWipFeatureEnabled":false},"isFallback":false,"isExperimentalCompile":false,"dynamicIds":["./components/seo/QAPageSchema/QAPageSchema.tsx","./components/community/Navbar/NavbarWidget.tsx","./components/community/Breadcrumb/BreadcrumbWidget.tsx","./components/messages/TopicWithThreadedReplyListWidget/TopicWithThreadedReplyListWidget.tsx","./components/nodes/NodeActionButtonWidget/NodeActionButtonWidget.tsx","./components/nodes/NodeInformationWidget/NodeInformationWidget.tsx","./components/messages/RelatedContentWidget/RelatedContentWidget.tsx","./components/customComponent/CustomComponent/CustomComponent.tsx","./components/community/FooterWidget/FooterWidget.tsx","./components/messages/MessageView/MessageViewStandard/MessageViewStandard.tsx","./components/messages/ThreadedReplyList/ThreadedReplyList.tsx","./components/community/FooterWidgetHelpLink/FooterWidgetHelpLink.tsx","./components/community/KhorosLogo/KhorosLogo.tsx","../shared/client/components/common/List/UnstyledList/UnstyledList.tsx","./components/messages/MessageView/MessageView.tsx","./components/nodes/NodeView/NodeView.tsx","./components/nodes/NodeView/NodeViewCard/NodeViewCard.tsx","./components/messages/MessageView/MessageViewInline/MessageViewInline.tsx","./components/customComponent/CustomComponentContent/TemplateContent.tsx","../shared/client/components/common/List/UnwrappedList/UnwrappedList.tsx","./components/tags/TagView/TagView.tsx","./components/tags/TagView/TagViewChip/TagViewChip.tsx"],"appGip":true,"scriptLoader":[]}
