mnmbeck's avatar
mnmbeck
Do I need a battery charger?
We just a 2010 Rockwood Roo 233S. I added a second battery (both new), and plugged the camper in to charge for about 24 hours. The camper does have an inverter. After one night of camping (using almost no battery), the indicator inside the camper is reading 1/2 charge. I have a friend who said that the battery charger in the camper is not sufficient and you still need to use an external charger....but his camper is quite a bit older than mine. Does anybody know if this is true? Hoping I will have enough charge for this minimal usage weekend!
  • RoyB's avatar
    RoyB
    Explorer II
    Post your converter/charger manf and model number.
    You need to have 18-20Amps of DC Current available from your converter for each battery in your bank if you have a smart mode converter/charger and want to re-charge your batteries in a quick three time frame....
    If you have less DC current available your batteries will still charge but will take longer...
    I suspect your 233S ROO has a 45AMP converter/charger installed.
    Roy Ken
