BradW wrote:
Mlts,
One thing is for sure, don’t buy a truck until you know what camper you will be hauling.
Brad
Some of the best advice is right here. Same thing I'd recommend, figure out which camper you can't live without, then figure out if a SRW will haul it to your satisfaction. Crew vs. Extended lengthwise isn't much of a difference, but sometimes the CG is a factor so check that out as well. The Extended cab will help push more weight to the front axle making handling and rear axle weights, less of an issue. Again, figure out the load first, lots easier than realizing you bought too much camper for the truck you have, or plan on getting. It would be a good use of your time to look at this forum and check out everyone's signatures/profiles to give you an idea of what they're using and what mods they did. Ask lots of questions and Good luck!
