SoundGuy
Jul 01, 2018Explorer
RVNewbie4now wrote:
I just bought a KZ Sportsman 291RKLE which is about 33' and has a loaded weight of about 8000 lbs. I'm pulling with a 1500 Silverado (well within its two capacity) with a Blue Ox Sway Pro wd setup installed at the dealership. My question is do I still need an anti-sway system too?
As it's name is intended to imply the Blue Ox Sway Pro weight distribution system already features integrated sway control, so the answer is no, there's no reason you should need a stand alone friction sway bar.
JMO, but I wouldn't tow any trailer weighing that much with my 1/2 ton Silverado. Power aside, you'd be running a minimum of 1000 lbs of gross tongue weight, possibly more, leaving little payload capacity for everything else. :(
44,026 PostsLatest Activity: Mar 03, 2025
