Timmo_
Nov 21, 2021Explorer II
Terryallan wrote:NamMedevac 70 wrote:
No and No you do not need WD bars.
Please explain? The hitch on 150 are rated for 500lb weight carrying. His tongue weight will be over 500lbs. While no he doesn't need the WDH to move it in the drive way. It would be unsafe on the highway, not to mention it would unload the front axle and cause sway with out the WDH.
And of courser it is possible I misunderstood your post.
Hmmm, my 2005 F150 has a 5,000 lb trailer (towing) capacity with a 500 lb tongue limit, but with WD, the numbers nearly double to 9,900 lb and 990 lbs respectively. So, yes the WD bars increase the tongue's load capacity but hard to imagine that moving a 4900 lb rated trailer in his driveway would overburden his truck.
