Bobbo
Nov 26, 2021Explorer III
Terryallan wrote:Bobbo wrote:Terryallan wrote:
And that's your opinion. A WDH . . . prevents sway. A TT that has a properly setup WDH will not sway, even without sway control. Sway control is only for those emergency events when you induce sway by dodging a road hazard, or accident. Sway control is not needed in normal driving.
However. A driver must take the time to setup the WDH properly.
This is not true. (I omitted the part that IS true, about returning weight to the steering axle.) Sway in a trailer is an oscillation of the trailer about the tow ball. It is dependent totally on the trailer's balance and vehicle speed. A WDH that has no sway control built in has absolutely no effect on trailer sway.
Now, a WDH may, and only may, help the tow vehicle resist the sway of the trailer, making it easier for you to maintain control, but it does nothing to prevent or stop the trailer from swaying. Again, if the WDH does not have sway control built in.
A properly setup WDH will prevent sway by returning steering control to the steering axle. A trailer with a properly adjusted WDH will not sway. With out the WDH the steering on the truck is too free, and will induce sway. Just as loading the truck with sand or gravel all behind the rear axle makes it hard to control the truck. the tongue weight does the same thing. And having the 5th wheel on a 18 wheeler slide too far back will also cause the tractor to move around.
Truth. You don't have to believe me. But experience towing all those vehicles tells me different. Just hook up with a 800lb tongue weight, and go down the road, and see how well the truck drives. Then hook up the WDH. See if you can tell any difference. The WDh makes all the difference.
Trailer sway has nothing to do with the steering axle. You are thinking of understeer and oversteer. Trailer sway is an oscillation of the trailer on the tow ball. Notice that the front axle is not involved. At all. Now, with improper weight on the steering axle, trailer sway is MUCH more likely to affect the tow vehicle, but the sway can be there anyway.
While you are correct that an unloaded front axle can induce sway due to poor tow vehicle control, sway is much more likely to be induced by other factors (improper trailer loading and speed primarily) even with a properly loaded front axle.
