Thanks folks. No, there is no electric brake system on this travel trailer. I would also need to get a different hitch to use a sway bar, as mine is a 3 ball hitch, with nowhere to mount the bar. Now I have a different question, if anyone can help.
TIRES..mine came with P205/75/14 load range "E". They are from 2007. I want new ones, but am conflicted with the research I've done on an LT tire vs a ST. I hear ST's don't last for crap, and have heard of many blow outs. I've also heard because of a stiffer side wall, I should only use ST.
I read too that LT on my small TT should be suitable. The load range may vary. With a single axle I really don't know if I want to risk a blow out. Also, as a woman, I can change an auto tire..does a TT change the same way? What kind of jack do I use?
I am starting to lean toward an LT tire. Can anyone give me some reasons why or why not? And what LT tire should I get that would be comparable, as I can't find the exact same size and load rating. I'm about to go nuts.
